Question about Dometic Rooftop RV Air Conditioner
Ac freezes up
Repair line leak vac and gas up 68 psi. unit was cooling good. left running for about 45 min and unit was not cooling pressure was 75 to 120 psi
  • 828 Answers
Exactly how much refrigerant did you charge into the system when you recharged it? If the suction pressure is varying that much you most likely over charged the system and got a liquid flood back which took out the compressor valves.
Posted on Jul 07, 2008
Whatis ideal r22 gas pressure required in 1 ton split ac of BlueStar.
Doesn't matter how big the unit is, pressures remain the same. On a satisfied temperature, approximately 75 degrees, r22 should be around 65 psi. The hotter the house, the higher the pressure. Head pressure varies on outdoor temperature. 90 degrees outdoor temp, approximately 200 to 225 psi on high side.
Jun 05, 2017 | Heating & Cooling
1.ton ac capillary pipe size and length I want to know. B coz suction line cooling level is very low gass psi 75
I'm guessing you should have 3/8 & 5/8 copper on that unit with a maximum of 50 feet. I doubt the line set size is affecting your pressures that significantly, you likely have a leak.
May 05, 2017 | Heating & Cooling
Ford f250 runs ruff and will not idle
fuel pressure should be 35 - 45 psi.could have faulty tps sensor.could have intake vacuum leak or ignition timing valve timing off due to worn timing chain.do engine vacuum test replace all vacuum hoses bad leaking egr valve diaphram or gasket will cause engine run poorly.
Jul 29, 2013 | 1997 Ford F250 SuperCab
High low side pressures and sight glass contains lots of bubbles
The system has a lot of air in it. If u haven't had any AC wk done on it that mean there is a leak in the system. System must be evacuated, pressurized & find the leak. Repair the leak, vacuum air from system & charge w proper AC gas. SPECIALIZED EQUIPTMENT & GAUGES NEEDED. good luck
Jul 28, 2017 | Cars & Trucks
Unit is freezing up
what type of gas?
if R410A it too low
if R22 check for inside air flow
Jun 23, 2012 | Gibson Nordyne/2 Ton Heat Pump Package...
Ac does not cool low side at 50 psi after putting in 1 lb of rerigerant changed out filter, orrfice tube and pressure the same
The low side should be 25 to 45 psi when the compressor is running, and 75 psi to 100 psi on a hot day when the compressor is not running.
Aug 09, 2010 | 1987 Buick LeSabre
Were di i recharge the ac on my car
if it is the 3.4 v6 the low side is on the passager side behind the motor. it should have a blue cap on it, and the low side is the fatter of the two ac lines
Aug 08, 2010 | 1994 Pontiac Grand Am
Air not cold enough to cool house
Make sure the outside fan is running. Also check the high side pressure, I assume the 70# is the low side pressure, so you can tell what the compressor is doing. If the fan and compressor are both working, make sure there is good airflow through outdoor coil and check that it is clean. Let me know what you find.
May 17, 2010 | Goodman CLJ24AR32 Air Conditioner
1998 Jetta TDI - AC compressor turns but no cooling
something not right here ,firstly why didnt you just renew the clutch instead of a complete compressor ?? secondly do you have a machine to recharge the system and if so are you using it correctly ,the reason i ask is because in the machine the low and high pressure pipes are interconnected in the body of the machine so yes it would show these pressures.When refilling a car once machine has weighed the gas leaving the bottle shut off the red line and start engine leaving the blue line connected ,run engine at 2000rpm with A/C on full for about 3 mins to draw the gas in from the machine .Then close blue line and and do a recovery to see how much gas was left in the machine.Also did you put compressor oil in when you re fitted the compressor about 100cc is enough ,this is better put in directly into compressor ,then vacumn to about -750mg or a stage one vac pump and omit the oil recovery cycle .When running the air temperature coming out should be about 7.5centigrade is good but some cars will drop to 5C anything below 9C is ok ,and forget to clean out pollen filter
Jun 08, 2009 | 1997 Volkswagen Jetta
1997 tahoe wont start
it is not the regulator if it has 40 lbs of pressure try to pinch off the return line and if pressure drops quickly it is either the check valve in the pump or the rubber seal between the pump and the sending unit
Nov 08, 2008 | 1997 Chevrolet Tahoe
Dometic Rooftop RV Air Conditioner Logo
99 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
