Question about V, Inc. Dump Trailer Pump 12v Dc Double Acting Hydraulic Pump
Its a 12 volt hydraulic pump with a hard-wired remote. I built the dump trailer at home using an old car-hauling trailer frame and bought the pump and reservoir unit from a trailer dealer. It has worked fine for 2 1/2 years though I have had to open the remote and clean the contacts once or twice. Now it will make a clicking/buzzing noise when the remote switch is closed for the lifting operation. The vibration is in the solenoid that is mounted on the motor body. I have cleaned all the electrical connections at the battery, switch, solennoid, etc., with no effect. I opened the solenoid last night to discover that it would be tricky to alter anything inside the body without damaging something. The dealer suggested that the solenoid might need to be replaced, or the valves may be dirty and stuck. Haven't opened the valves yet. Can you help me isolate the problem? Thanks, Chuck G
Bought a foldable Utility trailer (Haul Master) 1,195# capacity yesterday. Would we be able to purchase the back 4 FT section of frame only? Item # 62648
this is fixya we dont sell products you can try checking for parts with seller or notify haul master themselves
Aug 23, 2017 | Cars & Trucks
How easily can I install replacement trailer lights myself with my limited expertise?
Yes It only has two wires. the one leading to the outside of the bulb enclosure get grounded to the frame of the trailer. The other is 12 volts that goes to the center of the bulb.
May 23, 2014 | Da-Lite Tamiya 1/14 Flatbed Trailer Custom...
Got an covered trailer used to haul bikes.how can i light up the inside
splice into your trailer light hook up just the tail light one and run a wire to a 12 volt light
Apr 12, 2013 | Cars & Trucks
How do I prime the hydraulic pump om a dump trailer.
I've always just cycled a hydraulic system full open of the piston and then full closed. The air works it's way out on its own.
Feb 16, 2013 | V, Inc. Dump Trailer Pump 12v Dc Double...
Suburban towing package fuse box location
2005 Suburban Z71 4WD I had similar situation. No 12 volt positive to 7 trailer. Under my hood at the fuse panel, the red 12v + wire was connected to Stud # 1 which is on the left side of fuse box. There is a square fuse right next to this stud. I put a 40 amp fuse in it. I use this power to charge a battery in a trailer as I am hauling.
May 15, 2012 | 2005 Chevrolet Suburban
Have a 7x14 bray dump trailer dumps 3/4's then runs out of fluid. to fully dump i have to add fluid then as the box lowers down it pushes the extra fluid on to the ground?
When the dumping piston lowers, there should be fluid being taken into the other side of the piston from the return hose. The fluid level in the reservoir should not change. Has the hose routing been changed from original design?
Gary
Jul 26, 2011 | V, Inc. Dump Trailer Pump 12v Dc Double...
Trailer wiring 2008 Trailblazer SS
Sounds like the vehicle came with towing package. There should be 2 large wires and a smaller one. The blue "should" be trailer brake feed. The other large wire, usually the black, would be 12 volt power for trailer interior lights and battery charge. The red should be a smaller wire and it is the back up light wiring to the trailer. Most trailers don't use this wire, except for brake lock out on some boat trailers with hydraulic brakes. Also see http://www.etrailer.com/faq-wiring.aspx. All of this is used for5, 7, or 6 pin plugs.
Feb 04, 2010 | 2008 Chevrolet Trailblazer
Wiring issue on a 1965 Roadrunner Travel Trailer
Generic comments follow:
I'm not real clear on what you are asking ... I can almost guarantee you that you will not find a wiring diagram for your trailer.
Your travel trailer operates on 12 V DC. Your frig, the heater, all the lights, radio, all 12 volts. Your running lights should be getting power from the tow vehicle. While towing, the tow vehicle should be charging the battery. You may find some 110 volt lights inside, but probably not. To keep your battery charged, you have 110 Volt AC power coming in. Your frig may run on 110 V AC but it still needs 12 volts for control. Your Air Cond and Microwave and TV (if equipped) will al,so run on 110.
Regarding the three wires from the battery, there should be a battery charger close by your 12 Volt fuse panel. Even though the trailer is a "vehicle" dont depend on using the frame as a ground like you would in a car. So, that accounts for two of the three - a red or black and a white wire. There may be some dedicated line that the battery supplied to account for the third wire.
There should be a emergency breakaway switch on the front of the trailer. This is a switch with a pull pin. If the trailer breaks away, the pin is pulled out by the tow vehicle and the electric brakes should be automatiocally applied to stop the trailer. This switch should be powered, unfused, directly from the traailer battery and go directly to the electric brakes - presuming you have this feature.
Be aware, this trailer power supply was built and designed for a life style far different from that we enjoy today. If you have a 30 amp cord, as I suspect, 30 amps is enough to charge your battery, run your 12 volt items, run a TV and AC or TV and Micro or Micro and AC but not much else. As you are aware, you have two circuits built with #12 and they are probably protected with a 15 amp breaker though the #12 would be protected with 20 amp breaker in a house. The cord is only rated for 30 amps and it may be tired, unless you have replaced it.
I hope I have provided a little insight to your situation. If I can be of further assistance, please let me know.
a
Sep 20, 2009 | General Electric GE INDUSTRIAL SYSTEMS...
Wiring for a trailer
u must install the fuses for the system in he underhood heavy duty fuse box, it will be marked trailer tow
Mar 17, 2009 | 2006 Ford Escape
V, Inc. Dump Trailer Pump 12v Dc Double Acting Hydraulic Pump Logo
600 people viewed this question
Top V, Inc. Plumbing Experts
Tom Chichester
Gil Shultz
Are you a V, Inc. Plumbing Expert? Answer questions, earn points and help others
