Question about Pioneer VSX-819H-K A/V Receiver
I have a Pioneer VSX-819H receiver and everything works. But when I hook up my WII I can't get the video. I get sound. Ihave tried the DVD/VCR connections and the Video connections on the front. I have both a HDMI cable and component cables hooked up to the tv. My DVD player is hooked up to the BD component input. Any help would be greatly appreciated. Thank You, Jim Hall hallways2@aol.com
4 Suggested Answers
  • 6 Answers
SOURCE: I just bought a vsx-1019ah receiver. I connected
Check if your KuroLink is on or off. There are a lot of problems that users have been having with the KuroLink on. Since you have a Pioneer display, KuroLink might help in switching both the receiver and the display on and off together, but my advice to you would be play around with the settings (in your case, especially KuroLink). Also remember, the KuroLink is on by default i.e. if you've never changed this setting, it probably is on.
Hope this solution works, else check out the Official Thread on Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Posted on Dec 07, 2009
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
dunnbiker
  • 8546 Answers
SOURCE: how to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
OK? shows in the display.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Posted on Sep 08, 2011
My vsx-819h shut down and wont turn back on
hold "Advanced Surround" button, press "Standby" button for 3 seconds, unit will power back.
Jan 17, 2011 | Pioneer VSX-819H-K A/V Receiver
Is there a fuse for the VSX-819H
yes all appliances have a fuse , try to dettach all the speakers and plug it on ,if it work one of your speaker had a problem.( if your unit had a warranty bring it back to the dealer )
Mar 03, 2010 | Pioneer VSX-819H-K A/V Receiver
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Resetting the main unit
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
4 Press SOUND RETRIEVER to confirm.
OK
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
Installition manuel for vsx-819h-k
Here is the official link for your receiver. In case you need further help don't hesitate to post back.
Feb 24, 2010 | Pioneer VSX-819H-K A/V Receiver
I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
please press the accept button as I worked hard to answer you question.
Oct 24, 2009 | Pioneer VSX-819H-K A/V Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Sound Just Stopped Working
I have the same problem with my 49txi, and I called pioneer and a repair shop as well. Both told me that the 49txi has a known problem with over heating and that its boards unsolder themselves. I would have thought Pioneer would stand behind something this expensive, but that was the old Pioneer in the 80s, and the new Pioneer says we are on our own.
May 29, 2008 | Pioneer VSX-49TXi Receiver
Pioneer VSX-819H-K A/V Receiver Logo
74 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
