Need a wiring scematic to locate the dm module to replace caps for the microprocessors. Had a power outage the other night now the power light on the front of the set just blinks. Can anyone help me?
  • 10,594 Answers
You need pictorial to locate dm module in tv and to replace bad capacitors.
This Link will help you to locate dm module in tv and info about what are requirements to replace bad capacitors in dm board.
Hope this will help you.
Thanks.
Posted on Dec 29, 2010
My w-65909 was turned off and plugged into a surge protector we had a power outage that night next morning went to turn it on there was a blinking green light. I unplugged it and kept it unplugged for a...
Sounds like an issue with the DM pcb. most likely some small electrolytic capacitors. you will need to remove DM pcb & take cover off. look for capacitors with bulging tops. note the values & location & replace all capacitors with bulging tops.
Feb 01, 2015 | Mitsubishi WS-65909 65" Rear Projection...
Tip
Blinking Green Light on Mitsubishi Projection TV
Continuous blinking green LED on Mitsubishi's Projection which normally blinks after a power surge means that the microprocessors inside the unit are unable to communicate with each other. Usually Mitsubishi's Projection TV use 1000uF/16 in the DM MODULE (which is one of the two microprocessors), as these capacitors are too small for the load they get they usually fail usually after about 3-5 years.
They might also fail due to voltage fluctuations. To resolve this issue these capacitors should be replaced with 1000uF/25 volt or 1000uF/35 volt capacitors, so that they can handle any voltage spikes that will occur. To do the repair you’ll need to take the back off the TV apart in order to remove the faulty DM module and need to desolder the old capacitors on DM board and install new ones. All this is only recommended to be done by someone who has electrical expertise.
on Jan 10, 2010 | Televison & Video
We have a rear projection Mitsubishi TV, Model # WS-55511.We had a power outage last night and when the power came on this morning, we cannot get the TV 'ON'.There is however the TIMER light on the...
Thats a very common problem caused by weak caps on the DM board when power is lost they drain and then cannot recharge when the power is restored the WS55511 DM repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the caps and the cd with instructions.
Sep 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
We lost power the other night. Now I have a continuous green blinking light and it won't turn on. I have tried everything the manual says.
Try Going To The Mitsubishi Web Site. Downloading The Mitsubishi Service Manuals If You Don't Already Have It. It Will recommend The parts You Need To ordering. Circuit board photos are also shown which provide a visual reference during the repair process.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
Sep 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Need to know where capacitors are on mitsubishi ws 55511 tv are located at have back of tv off and cant locate them please help thanx
they are located inside the DM modules case( Metal Case on far left side ) open the metal case and you will see 7 caps on the DM power board. I am posting a pic of the board with the 7 caps that need replacement use 1000UF 25V caps to replace the 1000UF 16V caps that are currently installed.
Aug 08, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Blinking green timer light after power outage.
Failed capacitors on the DM and the Power boards. You can get the V26 Chassis DM/ Power repair kit from www.tvrepairworld.com which contains the replacement caps and the CD with instructions.
Aug 06, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light following a power outage
I rebuild the DM power supply in these sets with about a 50% success rate. Sometimes changing the 7 1000uf caps on the small power supply in the DM will fix it, you'll also have to solder the small 8 pin ICs as well. Do this carefully as you do not want an accidental bridge. If this does not fix your problem, replace the DM-POWER board not the DM Assembly. It's about a 300 dollar difference. You'll need a mitsubishi authorized service center to order the part for you. Goodluck.
Jul 05, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Flashing power light tv wont come on mitsubishi 1080
If the tv has the continuous flashing led, you have a DM board problem. It is likely bad capacitors in the DM module.. there are 4 of them 1000uf caps that will go bad. They will get a bulging top on them when they go bad. . Mits recommends replacing them with 680uf caps with a comprable or higher voltage rating. The DM module in on the left side of the set (viewed from the back) and is somewhat difficult to remove.
Dec 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsu wd-52628 green flashing timer/power light
steady blinking is the DM failing to complete the boot sequence. Your more than likely needing the DM repair kit.
Jun 18, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi ws-55513 green flashing light issue
I would asssume that the four cap replacement you're referring too is in the power supply of the DM module. (The large silver looking box on the left looking at the back of the TV)..
You can unplug that module from the signal board and remove it. Open the cover and you should find 4 16v caps in the power supply. If they look buldged chances are they are the failure. If not you might want to take an ESR meter to them to confirm they're okay and move on... In the back of that module is a small vertical board called the E2P module. Unplug it from the DM and plug the DM back into the signal board. If it powers up your picture might not be in the best alignment but you've identified the problem - just replace the E2P module.
If none of this works you're going to start getting into some greater technical requirements - but let's cover that when you get that far...
Bill
Dec 28, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
