Question about Dryers
My AEG Dryer Lavatherm 56800 starts and stops after 3 seconds with every program, Ive checked all the obvious but it still doesnt work. thanks for everything
TheMobilian
  • 8220 Answers
SOURCE: AEG lavatherm condensor dryer error
Make sure the water is completely out of the catch pan.
Posted on Dec 15, 2008
heatman101
  • 43501 Answers
SOURCE: I HAVE A AEG LAVATHERM 500 R TUMBLE DRYER 25 YRS
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 21, 2010
SOURCE: AEG Electrolux Lavatherm 57800:
try cleaning the drum contact on the rear of the machine. It is a carbon brush that contacts the drum spindle. It can get covered in carbon from the brush.Remove the plastic cover containing the contact brush, clean out all carbon dust and lightly sand the drum spindle to remove any surface build-up and ensure a good electrical contact then reassemble.
Posted on Jan 01, 2011
Macmarkus
  • 2605 Answers
SOURCE: I have AEG lavatherm 5230
Welcome to FixYa.
On the AEG dryers there actually are fuses for the heating circuit, usually two.
If you remove the back cover you should find a couple of fuse links in series with each element. There are 2 fuses ( which look like resistors ) on the inside of the element about 20mm up. These will be the non reset-able thermal fuses.
Also when replacing that back cover it is crucial the seal be in good condition as this will render your efforts futile once you re-install the back panel be allowing air to move across the element in a manner it shouldn't.
I will also inform you to check for negative air pressure in a room/closet not allowing enough make-up air to flow across the heater/fuses. ( if it's in a room closed, make sure there is a vent in the door or some other air supply for make-up )
The other factor which causes these fuses to trip is poor venting and opening the door during operation.
I don't have a part number, but the fuses typically come in a kit with a new heater as well.
Let me know what you find or if you have any trouble understanding my post so I can clarify.
I'll try to provide further assistance should you need it in any manner I can.
Good luck.
Regards,
Macmarkus :)
Posted on Jan 28, 2011
SOURCE: how do I understand the dial on the dryer AEG lavatherm 335?
How do I change (DIY) the belt in "AEG Lavatherm 335"
Posted on Aug 13, 2011
Have mislaid the manual for AEG Lavatherm protex plus. Where can I find it online? Can't access the model number as machine set in.
User's Manual - AEG Appliances
www.aeg-appliances.ca/wp.../AEG_LAVATHERM-T65179AV-_manual_070913.pdf
LAVATHERM T65179AV Dryer - ... In the AEG webshop, you'll find everything you need to keep all your AEG appliances ... read this user manual carefully, in-.
AEG - Tumble Dryer user manual, operation instructions
www.usersmanualguide.com/aeg/tumble_dryer 4, Lavatherm 310 A; Instruction Manual - Product Number Code:607625125. 5, Lavatherm 310 w; Instruction Manual - Product Number Code:607625014.
[PDF]LAVATHERM 75280AC EN User manual - User Manuals
www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL...pdf LAVATHERM 75280AC. EN User ... Thank you for choosing this AEG product. We have ..... Dry Plus. Extra Quick. Mixed. 3 kg. To dry cotton and synthetic fabrics,.
[PDF]LAVATHERM 76280AC EN User manual - AEG
www.aeg.co.uk/laundry/laundry/dryers/.../downloadpdf/?...User%20Manual... LAVATHERM 76280AC. EN User .... this user manual carefully, including its ..... Dry Plus . The wool drying cycle of this ma- chine has been approved by The.
AEG LAVATHERM 75470AH USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 75470AH View and Download AEG LAVATHERM 75470AH user manual online. ... filter, er filters DISPLAY Symbol On/Off Dry Plus Reverse Plus Anticrease Buzzer Time ...
AEG LAVATHERM 65270AC USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 65270AC View and Download AEG LAVATHERM 65270AC user manual online. LAVATHERM 65270AC Dryer pdf manual download.
User Manuals ' Service & Support ' AEG
www.aegaustralia.com.au/support/manuals/ Search for user manuals for your AEG products online with our finder tool.
manual for AEG Lavatherm protex plus Google Search
Jun 25, 2017 | AEG Dryers
I have a 14 yr old AEG 3200 dryer. The drum has stopped turning.Could this just need a simple belt replacement or wld you recommed a new dryer. Thanks
If you can hear the motor run when activated replace the belt. You should check or have checked the rollers that the drum is supported by. Check the belt tension-er replace if worn. While the unit is disassembled the rollers are easy to replace.
Vacuum all loose lint out from around the motor while disassembled.
These simple older machines are reliable and very durable and only have a few moving parts.
Hope this helps?
AEG LAVATHERM 60750225500 Tumble Dryer Section Spare Parts Diagram
Jun 21, 2017 | AEG Dryers
My aeg lavatherm 37320. Fluff is blowing back into the drum when drying.
You need to clean the inside of the dryer. A shop vac up the exhaust vent is the easiest way. If your hands are small enough you can reach i. There and clean it out. Obviously unplug the dryer first.
Sep 10, 2016 | AEG Dryers
Hi I have a dryer aeg 56800, when switched on for 11 beeps and light so they can help me?
Have you tried cleaning out your dryer vent? A Clogged Dryer Vent will lead to dryer malfunctions. You may want to look into a Dryer Vent Cleaning
Apr 20, 2016 | AEG Dryers
My AEG T37400 lavatherm standanlone tumble dryer works for a turns of the drum then stops.
Alarm conditions during operation of the dryer
The LEDs begin to flash if one of the following malfunctions occurs:
  • NTC open (the LEDs flash in sequence from right to left)
  • NTC short-circuited (the LEDs flash in sequence from right to left)
  • If the START button is pressed for more than 20 seconds while a cycle is in operation all the LEDs flash.
25679338-hf2jxxovvq5cn05mugly0fcq-5-5.jpg If the microprocessor identifies one of the conditions listed above, operation of the dryer is interrupted; the LEDs continue to flash in order to warn the user of the malfunction.
If the error is eliminated, the dryer returns to normal operation when the programme selector knob is turned to RESET and the drying cycle is re-selected.
Dado
May 04, 2015 | AEG Dryers
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
Dec 21, 2010 | AEG T58840 Dryer Electric
AEG Electrolux Lavatherm 57800: Push a program button, Machine starts for 3 - 5 seconds, Then stops and timer is on 0.
Nov 27, 2010 | AEG T57800 Electric Dryer
AEG Lavatherm 58800. Errors E54 - the motor cannot turn the load (but very little loaded) E51 - door suddenly opens
Hi if the drum is not stiff and runs free and the motor is energised but not powerful enough it can be thr start capacitor located nearby the motor. its a small cylindical silver can rated at 8 microfarads (125 00 20-33/4 approx £8.50 .) You cant measure it the best way is to try one known to be good. If its not that it is more likely to be the electronic board. You can look for cracked soldered joints and resolder (lead free solder) otherwise its a new electronic.hope this helps
Nov 19, 2010 | AEG T57800 Electric Dryer
I HAVE A AEG LAVATHERM 500 R TUMBLE DRYER 25 YRS OLD IT START RUNS ITS CYCLE BUT NO HEAT
heatman101
Sep 19, 2010 | AEG Dryers
How do I understand the dial on the dryer AEG lavatherm 335?
it should show a full sunshine for high and half a sunshine for low
Jun 23, 2009 | Dryers
Dryers Logo
110 people viewed this question
Top Dryers Experts
