Question about Samsung Digimax A503 Digital Camera
I have a sdhc memory card but when i put it in nothing happens, cant take any pictures anything? Is this the right meory card or do i have to program in or something?
    Scholar:
  • 66 Answers
Hi
The Samsung Digimax A503 is a very old camera which was developed long before SDHC cards were invented. As an example it's like you are trying to charge your Ford Model T from your household power socket - the Ford Model T wasn't designed to use electricity, just petrol/gas.
From the information I have the maximum car dyou can use is 1Gb SD.
Hope this helps
Regards
David
Posted on Dec 29, 2010
Memory card error appears.cant take any more pictures. what do i do now...
Your camera can handle MMC and SD cards. Modern SD cards are most likely SDHC cards and can't work in your camera. `please look for maximal 1 or 2 Giga Byte cards and the should not have SDHC or SDXC printed on them.
If your card is full, and it won't take more pictures, try putting most or all photos on a computer. Then delete the pictures you transferred. Make sure you also backup you pictures on an other medium.
Also check the lock switch on the memory card is NOT in the lock position.
Jun 22, 2014 | HP Photosmart M415 Digital Camera
Internal memory full
Internal memory is full after you shot only a few pictures Actualy you only have 11 Megabyte free for pictures. If you want to make more pictures, you have to insert a SD memory card. Make sure you buy a SD and not a SDHC or SDXC card, because nothing in the manual says your camera is compatible with these bigger cards.
If you happen to have a SDHC card you are free to try if it works, but don't buy one unless you are sure it works.
Jan 20, 2014 | Kodak EasyShare C913 Digital Camera
MEMORY FULL
The internal memory or the memory card of your camera is full. At least there is not enough memory free to save anything.
If you can't do anything, remove the battery, then remove the memory card and try to rescue the pictures on that card. There are recovery programs online, if you do have important pictures on the card. If you are ready saving, or you don't need anything from that card, try to format it on your PC. Just FAT will do. Then put the memory card back in and give it a format in the camera. Just to make sure the format is known bin your computer.
It could be there is no memory card in your camera at all, Because you forgot you did put it in another camera. Then just place a new one. BUT TAKE CARE. You only can use SD cards, because your camera is from before the SDHC period.
Or is a SDHC card in the camera already? that is the culprit.
Dec 09, 2013 | HP Photosmart M425 Digital Camera
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
Kodak easyshare M1093 refuses to format disk
The recommended card for your camera are those SDHC type or 2GB-16 GB SDHC card, try to use at least 2 SDHC card if this failed it means the memory card reader of your camera is already defective. Just in case this will happen try to contact Kodak at 1 800 235 6325 ext 12.
Feb 09, 2010 | Kodak EasyShare M1093 IS Digital Camera
Transferred the pictures from the memory card onto the computer and put card back in. Tried to turn it on, but now the lens is stuck, it didn't open fully, and I need help. It seems to have frozen while...
This would need to be repaired if the lens is stuck so is the shutter. I would take it in and have it looked at. there is no other resetting then what you already have done ot the unit.
thanks for rating.
Aug 31, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Cannot eject meory card
Perhaps the memory card has got stuck. you should use memory card readers always to use memory cards. Anyways try to use any plucker to try and take the Memory card. if that does not work call kodak @ 1800 421 6699 and they will replace the printer for yoy free of cost . But you will not be able to get the memory card back.
May 15, 2009 | Kodak ESP 5 Printer
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
Communication error
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
May 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Samsung Digimax A503 Digital Camera Logo
79 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
