Question about Yamaha Audio Players & Recorders
I have an audio receiver that powers up and the shuts down. I've replaced the power cord (due to rabbit) and the fuse. But continues to shut down??
    Guru:
  • 2,178 Answers
Why did you replace the fuse - did it burn out or opened? It's probably shutting down because it's detecting an overload. Inspect the circuit board for any shorts. I recommend having a repair shop isolating the problem. If it does blow fuses, then there is definitely a shorted transistor on the final amplifier output stage. Otherwise, if a fuse is shorted you don't need to replace it because it's suppose to be shorted.
Posted on Dec 29, 2010
Testimonial: "thanks, I knew there has to be a reason for it shutting down. It's too costly to replace so I'll search for a repair shop. Kdog"
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
How do i check to see what is causing my receiver to shut off
Sep 25, 2014 | Onkyo Audio Players & Recorders
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Shut off during loud play
Many receivers have a thermal "overload" switch that will shut down power to protect the rest of the unit if it senses an issue like excessive heat, or if the ohms or impedance gets too high. This is a safety mechanism and you should probably seek a qualified audio repair shop for further troubleshooting.
Nov 19, 2013 | Pioneer VSX-518-K Receiver
I tried hooking up an old polk sub to my yamaha rx-v659 av receiver. smelled wires burning smell. before i could unplug it, receiver shut down. now it will power up for about 5 seconds and shut off. manual...
If a fuse was blown, it likely would have no power. However if the power board has overheated, the capacitors may have swelled up and burnt out and will only allow it to power on for a few seconds, then shut down. The capacitors can look swelled up or burnt or have burn marks on the power circuit board. You can test them with a continuity meter. Each component has a printed number of it's voltage and ohm resistance so you can test them.
Jul 26, 2010 | Yamaha RX-V661 Receiver
The receiver is not turning on. Try all possible solutions ie;Power cord. What is cicurity protection and how do I check for that or correct?
Circuitry protection means the unit is overheating so a fuse blows and shuts down the power to save the electrical components.  You need to find the fuse and replace it.
Oct 25, 2009 | Yamaha HTR-5890 Receiver
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
Turns off when i turn it up
Does it power back up after it shuts down, if it does power back up it is unlikely it is an internal fuse, you would need to replace the fuse if that was the issue, could be an amplifier overload, check the demand your speakers require in watts, and be sure the right ohm speakers are being used, many receiver will display "overload protection"and shut down, and some just un-power to prevent a electical short from occuring.
Feb 02, 2009 | KLH R3100 Receiver
Haron Kardon 3375 Recevier Shut Down Problems
5 amp "slow blow" fuse where power cord connects to amplifier has probably blown. 9 screws holds the cover on, remove them and check fuse.
Dec 10, 2006 | Harman Kardon HK 3375 Receiver
Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Aug 18, 2006 | Kenwood KR-V8080 Receiver
305 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
