Question about Whirlpool Dryers
The dryer turns on and spins but no heat is being applied. Just curious as what my be the problem and how to fix. Thanks.
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
Indesit G74V dryer not spinning
sounds like you have a heater that is shorted to ground which will cause the unit continouoly heat but will not allow unit to start, in addition you may have a bad push to start switch or bad mtr centrifical switch. Best advice is to unplug until a tech can look at it or by a new one
Apr 16, 2012 | Dryers
Gew9200lw1 whirlpool dryer turns on, spins but doesn't heat up
hello, this is Mike. If your dryer turns on, tumbles, but there's no heat, I would bet that your heating element is toast. If you can access the terminals to the heating element, you can test them for continuity using a simple inexpensive tester. No continuity means they need to be replaced. If you would like some assistance with how to go about this and possibly fix the problem yourself, feel free to contact me. I would be happy to help you. thanks
Jul 18, 2011 | Washing Machines
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Dryer won't heat
The first thing to check would be the power, I know that sounds silly since the drum turns but your electric dryer uses 240 volts to heat and only 120 to run the drum. Check the circuit breaker or fuse by turning it off completely then back on.
If that does not fix the problem you have one of two components that have failed. Either the thermal cutoff or the heating element. The cut off is a small two wire heat sensing switch located just above the heat element. They are both accessible from the back
Apr 23, 2010 | Whirlpool LER5636P Electric Dryer
Maytag dryer stopped heating /drying
ON THE SIDE OF THE BURNER TUBE THERE IS A RESET THERMOSTAT- IN THE CENTRE U PUSH THE BUTTON.
Jul 08, 2009 | Dryers
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Dryers Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
