Question about Dell 3130cn Color Laser Printer
Remove Tape from Y Cart & Error Y Cart - Dell 3130cn Color Laser Printer
Receiving cartridge error consilt user guide, can you help mke?
Well, without knowing what printer it is or the full text of the error message, or what lead up to your proboem, this is a guess.
Wrong ink cart.
Empty ink cart
Missing ink cart.
Mis-installed ink cart.
Many ink carts have a piece of tape over the contacts or over an air breather hole. This must be removed before installing it.
Some printers have delicate contacts that can be bent or broken if the cart isn't installed carefully.
Jun 29, 2015 | Office Equipment & Supplies
Saying cartridge error when cartridge is inserted correctly
CLEAN JACK OF CART. & THE CARTRIDGE ITSELF & INSTALL YOUR CART. AGAIN
REMEMBER IF YOU USE REFILLED CARTRIDGE IT WILL SHOW ERROR ,SO ITS BETTER TON USE GENUINE HP CART.(ON INSTALLING GENUINE CART. IT WILL ASK FOR ALIGNMENT SO CLICK ALIGN WHEN PROMPTED.)
Feb 12, 2011 | HP Officejet 4355 All-In-One InkJet...
I have changed black cartridge but it says error message - tape on black cart 093-922 why is it doing this?
The cartridges have a piece of clear tape on them which needs to be removed before installation, keeps the ink fresh sort of. Take out the cartridge and then look for the piece of clear tape, remove it gently and re install.
Dec 03, 2009 | Dell Office Equipment & Supplies
Lexmark X5320 won't print acts like it's printing but paper is blamk, also tells me right ink is wrong( it is not)
Hello there,
The most common cause for printing blank pages is (1) Failure to remove the protective tape from the bottom of the cartridge. Even if you have removed the tape, there might be some residual tape left at the bottom of the cartridge. I would suggest you check out for this yellow or/and transparent blue tape at the bottom.Please remove it, if present. (2) If there is no tape left behind, then the next option is to clean the cartridge nozzles. I would suggest you go to Lexmark control program or Lexmark Solution Center and run the clean nozzle test. You should see solid dark lines on the print out. Repeat the process 2-3 times till you get a good output. (3) If all the above steps fails, don't worry.. we have one last thing to try... Remove the carts from the printer.. take a warm damp paper towel Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge. Repeat this process atleast two times and then put the carts back to the printer after 1 min (we need to allow the cart contacts to dry). Now you can install the cart to the printer and try printing. If you still have a problem with the cart, then I would suggest you try another cart as there should be something wrong with the cart that you have right now.
Merry Christmas!
Dec 21, 2008 | Lexmark Office Equipment & Supplies
Installed new colored ink and keeps saying " remove and check colored ink"
The cartridges comes with the protect tape at the bottom please its removed, if removed please clean the copper contacts with dry tissue , if you get the same error try the old cart if you get the same error the printer is faulty or if dont get then the colour cart is defective get it exchange if you had brought original cart as it comes with 6 months warranty...............
Jun 03, 2008 | HP Office Equipment & Supplies
Lexmark X6170
There will be blue tape when turn the cart upside down please remove the the tape ...and check there no tape :if the printer states the same error remove the cart and check for the error if error is displayed turnoff and remove power adapter for 30 sec and reconnet it back and check for the error If displaye it printer problem..
Feb 19, 2008 | Lexmark X6170 All-In-One InkJet Printer
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
Dell 3130cn Color Laser Printer Logo
268 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
