Rear trip switch keeps tripping, opening the back of the amp it appears the SL22 5R012 resistor keeps smokes, any ideas?
  • 6,771 Answers
You have a short in the rear channel, the smoking resistor is a good indicator of a bad output ic, also you should check the rear speakers for damage.
Posted on Dec 29, 2010
Testimonial: "that was a pretty quick response - much appreciated. I have to purchase a new limiter to replace the one that's blown and will check for a short -thks"
My washing machine trips the electric
take out the plug
remove the motor
now clean it ??
check the brushes or replace them if worn
or if you do not do this a new motor will be needed
as the motor safety switch will get blown
Feb 03, 2014 | Bosch Washing Machines
Coleman heater 3500a820 lots of smoke and now only blower works no heat
I am not sure about the heater type, but likely the heater element controller shorted out or the heater elements shorted - hence the black around where the wires go into the electric box. If you're lucky, the wires shorted to the side of the box. With the power off, open up the electrical box, mark which wires go where, remove them from the board, remove the wires from the electric box, then using electrical tape, tape up the exposed ends of the wires. Spread them out so they do not touch each other. Turn on the 60 amp breaker - if it trips, then your wires are bad and need replaced. If it does not trip, then the problem is with the heater. Do not let anyone near the wires when testing them! Don't forget to turn off the breaker if it does not trip. Again, turn off the breaker if it did not trip.
Oct 18, 2012 | Coleman Heating & Cooling
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch...
well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Jul 15, 2010 | Kenmore 24032\24036 Top Load Washer
Our Hotpoint ctd00 keeps tripping the fusebox, we
Disconnect the heater thermostats by poulling a wire off each stat, and then try it, if it still trips, then could be faulty motor.
The stats are located at the rear of the dryer, behind removeable cover.
Mar 25, 2010 | Hotpoint Dryers
Maytag mgr6775 trips CB after clean stove top with spray cleaner
first thing to inspect is where your cord screws on the range under the range let me know what you find and we will go from there and if you service computers you should join this site can pick up extra cash here
Feb 18, 2008 | Maytag MGR6775 Stainless Steel Kitchen...
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Sep 11, 2007 | Heating & Cooling
162 people viewed this question
 Grubhead
Grubhead
