Samsung dlp 4266wx problem
TV had picture but would shut down after minute or 2 with mess. that fan #2 was problem----replaced fan #2 plugged in tv and get no picture--now indicator on front is flashing a lamp signal-----does it have to warm up for some time since was unplugged for 2 days or do I have to replace lamp too now? I removed lamp to get access to fan replacement----any suggestions, already unplugged & replugged!
  • 11 more comments
  • bjn7295 Jul 07, 2008
    that does not tell me what to do now
    can you tell me why it only said fan# 2 originally & now after replacing that , led indicator is flashing lamp now----tv is only 18 months old!
    no help there, getting varied opinions
    should I replace lamp now or is it further problem. Manual says if dust cover not in properly tv will not operate, lamp dust cover is secured.
    still have panels off but the lamp dust cover is in place.....still getting lamp on led indicator?
    same thing
    continuous
    cintinuous flashes
    samsung DLP HLS-4266wx
    was careful not to touch cause I thought of that myself & not knowing for sure, took precaution. 99% SURE I did not touch!
    already have jangro site in my file & know how to change lamp, a lot easier than fan #2, so thanks but dont' need that----wanted to be sure not other problem before I spend $180 for lamp, can u understand why questions before replacing?
    not new lamp, old one still in-------after replacing fan#2 got indicator flashing ...lamp
    I will just go ahead & order lamp & replace, just wanted to be sure before I spend the money that that is the problem & not something else could rectify itor I did something when replacing fan#2, would like to know for future ref.
    Everyone agrees to just replace lamp! I am novice & unable to check ohms, etc.
  • bjn7295 Jul 08, 2008
    did not need lamp as all experts suggested.....only needed to put final panel on back that triggers switch for lamp......tv is working just fine, have to call & cancel lamp order now that all experts said I needed. Replaced fan #2 & the lamp is fine
    Thanks for all the costly help......I think I am the expert,not you guys, it was very simple solution no one suggested, everyone saying new lamp! That is why I kept questioning why it did not say before.....that should have been tip off for experts, no?
    Want my money back!!!!!!!!!!
  • 2,071 Answers
  • 2,322 Answers
It's very unlikely that the new lamp is burnt but you could use a ohmeter and check for some resistance from the lamp filaments.
If the lamp is not powering up is more likely that the lamp ballast is defective. In this type of TVs the ballast works like a FBT to provide the necessary power to the lamp.
Check this site for the ballast availability.
Posted on Jul 07, 2008
  • Jaime Hernandez Jul 07, 2008
    I would suggest to check Youtube on how to use a multimeter, just in case you need to in the future.
    Good Luck.
    Master:
  • 788 Answers
If you touched the lamp with your fingers then it is burnt. You will need to replace it.
  • Dean Joly
    Dean Joly Jul 08, 2008
    Abrsvcs suggested that you check the access panel. If anything your FixYa rating and money should go to him.
  • 19,396 Answers
How many flashes do you get?
  • 4,234 Answers
Carefully cheak the access doors for proper seating. If the lamp or the protective cover are not in the correct positions, the safety switches will prevent proper operation and show this. It is possible that the lamp is bad, but I'd double check all of the access panels first.
Keep us posted.
Dan
    Genius:
  • 1,665 Answers
Over half the sets , the cause is bad(dry) joints
true the transistors and other bits may have blown, but usually the original cause is a dry joint.
The wait for fault to occur (use hair dryer to speed up process)
then spray an area, then wait 30 secs to see if any change
then another area and so on, when you get a response
spray a smaller area within the last area, and so on till part located of course when you get down to a smaller area,
you can reheat with the hair dryer, to confirm.
other wise take it to an authorized service station to have an estimate.
    Genius:
  • 1,689 Answers
The "flashing lamp signal" indicates an internal error on your unit, check the manual on the model on what settings are to be changed and / or replaced.
  • 6,487 Answers
Now you should replace the lamp too , because it already showing on the led indicator that it already needs a replacement.. so if you already have a new lamp have it replace already..
Hope that helps.....
  • 6 more comments
  • Mark Gil
    Mark Gil Jul 07, 2008
    Check this link it will help you with the replacement http://www.samsung.com/us/support/popup/...
  • Mark Gil
    This one has the stpe by step way how to replace the LAMP http://www.jangro.com/a/2006/08/03/how-t...
    Hope that solve your concern.....
  • Mark Gil
    There's a possibility that when you replace the fan#2 the lamp got burn out, because that led indicator is a sign that the lamp is busted /defective that why you need it to be replace..
  • Mark Gil
    Yes you need to replace the lamp already.. and the link that I gave you will help you for that....
  • Mark Gil
    Did you already replace the lamp>>
  • Mark Gil
    If you already change the lamp make sure it properly connected..
  • Mark Gil
    Are you talaking about the old lamp that you have not touch it when you replace the FAN#2?
  • Mark Gil
    Ok because base from you have said that you didn't really do any contact with the lamp when you replace the fan so I believe lets wait after you replace the lamp but I'm sure that after replacing the lamp everything will be fine..
  • 1,879 Answers
Greetings,
Now the projector is having a problem with the lamp as the LED indicator displays.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Tv will power on not picture
I would have the power supply checked for the screen and then have the power button checked it may be faulty.
Sep 20, 2017 | Panasonic WD65638 Mitsubishi WD65638 65""...
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Shuts off after a few minutes
This is a common problem for samsung DLP tvs and is due to the age of the lamp.
See this article for some solutions to extend the life, but in the end, you need a new tv or a new lamp.
http://www.ehow.com/how_4802985_fix-samsung-dlp-tv.html
Mar 07, 2011 | Samsung HL-S5087W DLP TV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
I've a Samsung DLP Model HLR-4266WX that has started to hum and is distorting the picture. I've replaced the cooling fan on the heat sink in the back and that didn't work. Is there another fan in the set...
Color wheel would be cause of hum noise and distorted picture on screen.
Please note that color wheel is not user level repair and requires expertise because it is located in light engine, the most sensitive and expensive part of dlp tv.
If you are good with electronics stuff fix then have service manual copy in hand to start inspecting color wheel.
Aug 26, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung tv turns off on its own model hls4266wx
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Mar 12, 2010 | Samsung HLS4266 TV
    My samsung dlp tv model#hln617w keeps turning off. Only stays on for 2 minutes. I replaced fan #2. Thunking that was the problem.
    Why did you replace the fan was it noisey and did that cure the noise. These sets commonly have problems with color wheels-do you get motor noise at startup?
    Sep 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
    61" samsung DLP 3 years old. Keeps turning off by itself.
    Get a small but powerful used computer fan and place it in the TV to replace the defective old fan.That's the best way.The factory fans in these TVs don't last.
    Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
    HL-S5687 DLp tv
    your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
    I believe the left side is your high-voltage section.
    you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
    Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
    Televison & Video Logo
    418 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
