Question about Mercury Computers & Internet
I am antony prem from chennai, i bought PI945Z motherboard few month back, for past four days i cant boot in to the system, as the system is on it immediately switches off automatically, there is no warning or any error indication, i even changed my smps also but still facing same problem. please provide me solution.
  • 10 Answers
SOURCE: Error displaying 552
Hi ladakh the fuser unit has failed to reach its required temperature there are 3 possible causes 1.the thermister is faulty 2.the heater lamp has blown 3.the power supply is faulty you need an engineer to check and replace any parts
Posted on Mar 05, 2007
KOakaKO
  • 135 Answers
SOURCE: memory recall
From the Users Manual for this monitor: "Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting." When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2. If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that. It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck. Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife. If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty. One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows. Hope that helps solve your problem...
Posted on Aug 03, 2007
Gixer6irl
  • 10 Answers
SOURCE: !!! TOSHIBA SHUT DOWN !!!!!!!
My Mom's Toshiba Satellite had a similar issue, started running hot, got a laptop cooler, that worked for a while. Then it started to shut-down without warning. I thought it might be a bad power supply/defective battery. Did a search, found a user group that filed a class-action lawsuit about this issue. Turns out many of those laptops have a design flaw. There is a gap between the CPU heat sink and the intake fan. Apparently the gap gets clogged with dust, animal fur, lint, etc. I removed the bottom cover & discovered the gap full of lint & cat fur. I gently peeled the strip of lint out with a dry cotton swab (wore anti-static wristband while inside of laptop), then blew out the inside of the laptop with canned air. From there I tacked fine nylon window screening inside the bottom cover over the fan vents (very sparingly with Krazy Glue). After the glue dried I replaced the bottom cover, Mom hasn't had any overheating issues since.
Posted on Aug 12, 2007
sandrew
  • 2961 Answers
SOURCE: Boot Problem with biostar 945 GZ SE Micro Socket 775
you may have a short somewhere, maybe against the pc case or a cmos chip fault. You could have stressed the board when fitting the tv card, or the motherboard was simply faulty at purchase. You will have to reset the bios by the shorting terminals (refer to manual) as removing the battery alone does not always reset the bios.
Posted on Aug 21, 2007
SOURCE: System Fault. No display nor beep sounds.
Check Bios update.
Posted on Oct 11, 2007
Is a landlord aloud to use current month rent to pay past due rent without letting me know and give me a 3 day eve notice for not paying current month rent????? please HELP!!!
Renting property is different from state to state, but a 3 day eviction notice is way below the minimum days allowed. My advice would be to look at your state's renting eviction policies to get full information about how to go about this.
Dec 11, 2014 | Heating & Cooling
I bought a Samsung Galaxy Tab 2 four months back. For the past few days, whenever i try to access the gallery, my files, music player or gmail icon, it goes to the respective page and then flashes back to...
You may have run out of memory on the system. I would suggest getting a SD Card, then go to your settings and you can click on each of your apps and transfer the ones you want to the SD Card, taking up less space on the Device memory.
Sep 15, 2013 | Samsung Galaxy Tab 2 10.1 16GB 3G Wifi...
I want to download mercury pi945z mother board drivers for windows7 os
The best way to find your system compatible drivers is to search online. When online, open your browser, type "Drivers for Mercury PI945Z motherboard" and make a google search. Try to find out the search results from your Motherboard Manufacturer site. The site of your motherboard manufacturer will show all compatible drivers for your Motherboard model. You then can download them all from the site, and easily point out which ones are compatible for your Windows Se7en OS.
Dec 13, 2010 | Computers & Internet
Will not boot past Logo screen with new XFX nvidia Gforce 9500Gt 1gig card
DD SYSTEM SOLUTIONS
(MOTHER BOARD CHIP LEVEL SERVICE CENTRE)
OLD NO.28, NEW NO.67, II FLOOR
SESHA CHALAM STREET, SAIDAPET,
CHENNAI - 600 015.
PHONE NO : 98405-11595
Apr 30, 2009 | Intel D915GUX Motherboard
Cant get past windows xp screen
http://downloads.drivershq.com/DD/driverfiles/5/DriverDetective.exe
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Syntax SV266M Motherboard
Bought a new made in China dell optiplex 330 in Ghana for only four months now but have not been booting for the past month.l have taking it to the dealers three times since there is a warranty covering...
I am not sure about how your wiring is in your home, but these newer systems require more stability with the electrical wiring and if there is a ground fault where you have the computer this would cause the problem you are having. Try another location and see if this changes, if not? try looking into replacing your power supply located on the back of your system. Good Luck
Fehdi
Jan 22, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
When booting power dorops of after few seconds
Unplug your hard drive cable and see if still powers OFF after a few seconds.
Mar 15, 2008 | ASUS M2NPV-VM Motherboard
Computers & Internet Logo
83 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
