Question about Reddy R60A Utility Heater
Since reddy heater is shut down i have no where to turn i bought a 110000btu reddy heater and if the tank is half full or more it leaks i tried silicone but it still leaks where can i get a tankor who will warranty this
  • 1,476 Answers
Biggmc1969,
Go to http://www.reddyparts.com and if any tanks are available they will have them.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 30, 2010
The heater runs 3 to 4 minutes then shuts down. i unplug the re plug and it does this again over an over. i just replaced the igniter a week ago. any ideas?
A couple of things come to mind:
Restricted air flow. Check heater inlet and outlet. Remove any obstructions.
If the heater has been used in a dusty environment, it may simply need a thorough cleaning.
Inadequate propane supply. Make sure there's enough gas in the tank to facilitate combustion.
If the tank is full, turn of the tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve on very, very slowly, until it's fully open and try relighting and operation of the heater.
If you have misplaced your Owners Manual, you can find it at www.deastech.com
Hope this helps to solve your problem.
Mar 02, 2011 | Reddy Heater Tools 60,000 Btu Portable...
I turn on unit and it starts---Very shortly thereafter it shuts down and light indicates" Flame". There is fuel in tank , but not full. Please advise
donaldcfield.
This is a typical Reddy Heat problem. You need to see my tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix it and where to get the parts.
hardrocko
Feb 17, 2011 | Reddy HEATER RH125T 125,000-BTU...
My heater runs great for about 15-20 minutes and then raw diesel comes out and it shuts down. I thought maybe the tank vent might not be working right so I tried running it with the tank cap off and it...
The transformer gets hot and stops making spark... then fire goes out....transformer cools down and it works till transformer gets hot...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 02, 2011 | Reddy R155D Utility Heater
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
My Reddy Heater runs a little then shuts off
It sounds like you need to replace the thermostat in the unit! ( avery common problem in this model!
I hope i was if help!
Dec 14, 2008 | Reddy R60A Utility Heater
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy R60A Utility Heater Logo
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
