Tip & How-To about Kenmore Elite 45986 Front Load Washer
Rear Tub
Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most
Kenmore Elite HE model FRONT
LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT
LOADER models. This is a repair that
would be rated as difficult due to the extensive disassembly and
reassembly of components.
The requirement to replace the rear wash tub shell is
usually attributed to the rear tub bearing failure in which the bearings are
molded into the tub and cannot be replaced otherwise. In some situations the replacement of the
inner spinner basket (stainless steel tub) may also be required due to the
corrosion and breakage of the spider arms in the back of the basket that
support the basket.
SYMPTOMS:
Washer exhibits excessively loud “rumbling” type noise during the spin
cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD:
With the washer door open, place your hand inside the basket and push straight
up. If there is excessive play in the
tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the
outer tub shell when you give it a spin, you will have to replace the inner
spin basket as well. Unfortunately, you cannot see the condition of spinner
basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain
my show up on clothing as the bearing seal has been breached and leaks into the
spinner basket.
Before starting this repair, make sure you read through all
instructions thoroughly and place the washer is in an area that gives you
plenty of space to work.
(cont’d)
