Question about Kenmore Washing Machines
Our brand new kenmore elite model 796.2927 makes a lot of loud noises when in spin cycle, no matter what the load is or its size, is this normal?
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Posted on Jul 30, 2007
duby1990
  • 367 Answers
SOURCE: Very loud spin cycle
your bearings i the tub have gone bad. It happens usually if you use powder soap. It doesnt dissolve all the way and gets into the bearings and ruins them. Sorry but this is a pretty expensive fix. When you get it fixed used liquid soap and it shouldnt happen again.
Posted on Nov 18, 2008
SOURCE: knocking noise
Your problem may not be a broken spider assembly. My Kenmore Elite (model # 110-42822-203) had a kocking problem as well. After taking the back off, I discovered that the nut holding the pulley to the drum shaft (on the outside of the outer basket) was slightly loose. I simply re-tightened this an the knock went away. The pulley was shifting on the shaft ever so slightly, leading to the knock. Cost of fix: $0. :-).
Posted on Apr 05, 2009
SOURCE: my kenmore 417.42042100 model front
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
Posted on May 15, 2009
  • 5 Answers
SOURCE: kenmore elite he3.on spin cycle makes lots of
It could be that you are not setting the water level high enough when you do large loads.also the strap that holds the cement block could have come undone and now the block is unsecure.
Posted on Jul 18, 2009
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Loud noise during spin cycle Kenmore Elite model 110.20952991
check balancing
look in side the lid small clothes some how may fix anywhere inside
Jul 23, 2009 | Washing Machines
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Makes a very loud noise on spin cycle. Seems to worsen with larger loads.
sounds like a rear bearing gone bad , not exaectly a doit yourselfer. pretty costly as well id call sears, for possible part warr. and how much theyd charge to replace the rear bearing?
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
229 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
