Question about Medion MD 96340 Laptop
Hi, i have a problem with the port hole connecting the power supply to the laptop. i think a part has come lose as it does not charge the battery to the laptop. I need to send this back for repair, how do i go on about this? Regards Gary
  • Medion Master
  • 6,771 Answers
Check out your local computer repair store, there are some that will fix your laptop.
Posted on Dec 29, 2010
Dell Studio 1558 warning battery cannot be charged (still at 100%)
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 20, 2013 | Dell Computers & Internet
100% cpu while charging
Hi
I had the same problem. Replaced the battery and everything is OK now. Hope, not too late.
Rgrds
Doh
Jun 18, 2012 | Computers & Internet
My acer 5920 wont charge or wont work on ac adaptor but the ac adaptor works fine on my friends laptop
Either the AC port on the back of your laptop has a lose connection - if operation without battery is an issue, or if battery charge only is issue - then battery may have to be reseated or it is at end of life. Test by removing battery and running AC alone. if connection port is bad, laptop will power off immediately/unexpectedly. Good luck! btw - batteries for this unit are around $40 on ebay
Jun 14, 2011 | Acer Aspire 5920-6706 Notebook
The power button doesnt start the laptop
Toshiba Satellite R15-S822 Tablet: Battery is charged and operational power supply (charging light is on) is plugged into power port on back side of laptop: Problem is sliding "power on" switch does not start laptop - no sign of any electrical activity...
Nov 04, 2009 | Toshiba Satellite R15-S822 Tablet PC
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Power problem - led shows the ac plug is in - battery does not charge - can not run laptop on ac adapter - what is causing this problem
The connection to the power supply inside the Pc is or has gone,
because your using the connection 1000 times a year, it faulters, and fails.
$150/$200 to get repaired.
Strip out the laptop solder connection back up,
rebuild, very common problem.
Regards
Richard.
Apr 18, 2009 | Toshiba Satellite A135-S4527 Notebook
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
Apr 10, 2009 | HP Pavilion dv6000z Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Power
Did the battery seem to lose it's charge rapidly prior to this, this would be an indication of a battery losing it's useful life, or a problem with the charge system.
Have you tried to take the battery out, plug the computer to a wall outlet granted you have the power adapter which is the same as the charger cord I would think. If that works I would say you need a new battery. Sometimes the plug port where it connects in the computer wears, so try and wiggle the cord if you didn't get something the first time.
Matt
Nov 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
Medion MD 96340 Laptop Logo
53 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Martin Murray
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
