Question about Nady Systems SPA 850 Amplifier
Nady 850 amplifier problem
When I bring a Karaoke song up the amplifier does not start up most of the time, if it does work, it only comes up maybe half power, what is the problem.
  • Anonymous Aug 02, 2008
    my 5amp fuse everytime i on my karoke amplifire. Changed the fuse still the same thing happened.
  • 682 Answers
Check your speakers cables for short circuit-disconnect all speakers and connect them one by one until you find the bad one and when you find it try the cable first then the speaker -if all above failed you will have a problem in your amp and ask for help from service center
Posted on Jul 14, 2008
Nady Systems XA-900 Amplifier
If the fan is thermally controlled then either that channel is not heating up enough to turn the fan on or either the fan or thermal switch has malfunctioned. The first thing I would try is to swap the fans. If the problem moves with the fan, then the switch is the most likely culprit. The fans are probably termally controlled so that they are not energized when the volume is low to reduce background noise.
May 05, 2014 | Nady Systems XA-900 Amplifier
My siglos karaoke program is dropping songs out, how do I correct
clean the lazer, if you can do it yourself, cotton and vodka or gin if you have none then don't waste your money on the drink insread buy some surgical spirt, dont use to much thou and don't put a lot of pressure on the lense, most times the lazer get's to much for a cleaning disc to handle, hope this helps :)
Nov 30, 2013 | Audio Players & Recorders
My Nady xa-900 shut off during performance with no prior indication of problems. Now it will not turn on, no lights or anything. I have two of these amps. One was running Hi Packs, and the other 18
The amp top should be removed to check any fuses and the power transformer, a digital meter will be needed to run these tests, post back for instructions if you have one.
Jul 08, 2012 | Nady Systems XA-900 Amplifier
How to know the serial number of output of nady pmixer 420
Serial #s are usually on the rear or bottom of the device. # of outputs- 2 subs & Mains L&R= 4
you can find the manual below.
Good Luck mixing the Next Big Hit!!
Aug 31, 2011 | Nady Systems SPA 2400 Amplifier
How to upgrade new songs to my Platinum BMB-ONE HDD/DVD player
How to update songs (Hard Disk Model):
Method 1 - Single Volume Update Only
This method will require a Flash Drive.
Song Update data and Certification Key data will be written in the Flash Drive.
You can bring home the Flash Drive and be able to update the Platinum karaoke player by your own easily.
a. Bring a working Flash Drive to a Platinum Karaoke branch near to you and surrender it to our sales representative. Be sure to get a receipt. Your flash drive free space should be atleast 1 GB.
b. Our sales representative will then send your USB Flash Drive to our Head Office for processing
c. The process will take about 5-7 working days
d. Once you get your Flash Drive, ask for instruction on how to use the Updater
Method 2 - Multiple Volume Update
This method will require a USB Flash Drive and Hard Disk Drive in your Platinum Karaoke player.
Hard Drive will be re-formatted and be written with Fresh Updated data.
Certification Key will be written in the USB Flash Drive.
You bring home the Hard Disk Drive and Flash Drive, re-install the Hard Disk Drive in your Platinum Karaoke unit, and insert the Flash Drive to run Certification process.
a. Carefully disassemble Hard Disk Drive from the Platinum karaoke unit.
b. Bring the Hard Disk Drive and 1 USB Flash Drive (at least 1 GB of free space) to our sales representative nearest you (See List of Branches here)
c. Our sales representative will then send your Hard Disk Drive and Flash Drive to our Head Office for processing
d. The process will take about 5-7 working days
e. Once you get your Hard Disk Drive and Flash Drive, ask for instruction on how to finalize the Update process
How to Install the Update:
a. Make sure that the unit is switched off.
b. Attach the Flash Drive/Hard Disk/SD Card into the unit. For X2 model please note that MicroSD is not applicable for update.
c. Switch the unit ON.
d. Update will automatically run. Wait for the unit to automatically shut down.
e. Remove the Flash Drive/Hard Disk/SD Card. Switch the unit ON.
f. Update is Complete.
How to update songs (DVD Model):
a. Directly purchase DVD (comes with additional song list) from a Platinum Karaoke branch near you.
b. Play the DVD and enjoy your newly updated songs!
Nov 09, 2010 | CP Technologies USB HDD Platinum Series...
Just got new acer desktop. Downloaded latest itunes. Transfered all music over to this itunes all 850 ish songs. Everything fine.everytime i try to synch my ipod touch with itunes it synchs maybe 60 - 70...
restore your ipod to original factory settings... unfutunately you will need to use itunes for that, hope it does not freeze... good luck!
Jun 23, 2010 | Apple iTunes
Download karaoke songs to laptop.
Well you can download lime wire from and you can very well run on this laptop or you can go for Any other laptop depending upon your budget,taste & availability.
Sep 06, 2008 | Dell Inspiron 6400 Notebook
JB199 karaoke machine
Try hooking your cavs up with a keyboard and a mouse get your desk top up and you will notice new updated . udated and it will work again. make sure you register song files after u up load
Jun 18, 2008 | Cavs JB199-160GB Karaoke jukebox & Digital...
Nady Systems SPA 850 Amplifier Logo
116 people viewed this question
Top Nady Systems Audio Players & Recorders Experts
Michial Gueffroy
Corey Bartlett
Level 1 Expert
Robert Graf
Are you a Nady Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
