Question about True Blue TB-50CR Bluetooth Headset
My tb20el true blue bluetooth will not turn on after it has been charged
When I plug up the bluetooth to charge the red light appears then it blinks blue red does that mean it is charging or not because it is not working with phone
That might meaning that's it's draining the residual charge left on the battery, before it can be charged, but if it does this for more than an hour, your battery is "toast".
Aug 28, 2014 | Universal QuickCell Q7 Bluetooth Headset -...
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Motorola H710 Bluetooth Headset will not turn on!
I have the exact same problem with my Motorola H710 Bluetooth Headset. When I charge the headset a green light is displayed. After the charge is complete I unplug the headset and NO light is displayed. I flip open the boom and NO light is displayed. I hold the call button for 10 secs or 10 mins or 10 hours and NO light is displayed. There is suppose to be a blue light displayed to indicate that the headset is ON. Since there is NO light displaying that means the headset is OFF. So my headset DOES NOT TURN ON! I did my research no where online can anyone give a solution. All the above solutions given does not help because the blue light DOES NOT turn on. No user guide or customer service rep or tech support can help that is what I found out. So I guess I will toss my headset in the garbage!
Nov 26, 2011 | Motorola Mobility H710 Bluetooth Headset
My bluetooth seems to charge up but will not turn on
Yes, when it is charged, light will turn blue.
It is alright.
electronics wholesale
Nov 01, 2011 | Samsung WEP200 Headset
Setup for trueblue/bluetooth, Tb20el
start in the off position press and hold the talk button and you will hear a tone continue to hold for another 7 seconds (10 seconds total) then the light should be flashing blue then red it is now in discovery mode now take the divice you are trying to pair it with and do a search for blue tooth devices. once it is found you may need a password it is 0000 as is the default password for all blue tooth devices hope this helps.
Apr 30, 2009 | Radio Communications
Need passkey to connect my tb20el bluetooth to my phone
for tb-20el:
1. ensure that your phone's bluetooth feature is on
2.Ensure that the headset is off(press and hold button on your headset (called multifuntcion button) for 2-4 sec, teh indicator light will flash red)
3. press and hold the multifunction button for 6-8 seconds until the indicator light alternately flashes blue and red
4. set your phone to find new device
5. Ente rpin '0000' (four zero) then press OK or yes
6. this should complete the pairing.
Apr 14, 2009 | Motorola Mobility H700 Wireless Headset
Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
Dec 19, 2008 | True Blue TB-50CR Bluetooth Headset
Cant find bluetooth device
be sure to hold down the button on the bluetooth till it blinks red and blue together, than make sure the phone bluetooth is on and than press find device. should solve your problem
Apr 27, 2008 | Motorola Mobility RAZR V3
True Blue TB-50CR Bluetooth Headset Logo
137 people viewed this question
Top True Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a True Radio Communication Expert? Answer questions, earn points and help others
