Question about ValuSoft Let's Ride! The Rosemond Hill Collection
Everytime i play my let's ride rosemond hill game. i get to the second show and it shuts down and give me some address
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
My ps4 is shutting down automatically after playing for 5/10 minutes. What to do?
it looks like it is heating up. heat fan replacement can solve the problem.
Mar 01, 2015 | Computers & Internet
I was playing my ps3 and during online play the game just shut down and the red light was present afterwards. I tried to go touch the on switch and it turned green for like 3 seconds and shut back down....
There are series of problem in ps3 which can be solved without much technical knowledge........ Your problem belongs to that so don't worry i will give you the link to download the ps3 repair guide that will help you a lot....
Click here to download PS3 repair guide
Jan 05, 2011 | Sony Playstation 3 (PS3) Console
Monitor shuts off randomly!
1. This is main-board related. You either have a Micro controller or power supply issue that needs to be address by a tech. Shut down is direct relation to a circuit component in the start up that has failed.
May 01, 2010 | ASUS Eee 4G Notebook
Back fires everytime i shut it down after
When you finish cutting, bring the engine down to idle for about 30 seconds (some say 5 or 10 seconds but I have found a little longer doesn't hurt anything and sure doesn't scare the heck out of you) before you shut it off, If you shut it down wile it is still turning fast, it will continue to feed fuel into the cylinder and out into the hot muffler where the heat ignites the vapor causing the backfire.
Sep 23, 2009 | Garden
PS3 Refuses To Play Certain Games
do we really need the Sony PS3 2.43 update to fix the current 2.42?
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
ValuSoft Let's Ride! The Rosemond Hill Collection Logo
66 people viewed this question
Top ValuSoft Video Game Consoles & Games Experts
James Wishart
Tom Chichester
Charles A Stimeling
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
