Question about Hotpoint VBSR3100D Top Load Washer
Won't drain or spin
When it hits the drain / spin cycle it sounds kinda like a cell phone on vibrate, but more hollow and not steady - more like a bolt bouncing around on top of a running lawnmower. It just sits there vibrating sound. Sometimes it is just silent - nothing. It did work once on perma press cycle. It drained and spun. Wish I would have quit there. Now it is full of water again. Roland Comfort
  • 3 more comments
  • brokenwash2 Sep 14, 2008
    Same as above
  • Anonymous Sep 23, 2008
    hey I have the same problem washes fine will not drain water after wash just sits there like power has been turned off have to use a garden hose to empty the tub start over fills up again washes fine same as before will not dump water just cuts off
  • Anonymous Oct 01, 2008
    it just wont drain out and spin just sits then runs another wash cycle
  • sborsh99 Nov 23, 2008
    Won't drain or spin!
  • Anonymous Mar 02, 2009
    washer won't spin
My hot pointtopload will not spin or wash
Posted on Sep 01, 2008
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
My washing machine won't go to high speed spin to remove water from clothes.
Possible there is no switching for the cycle from the controller or there is speed limited due to sensor action for vibration. Check the leveling of the machine, if not use rubber footing to hold the machine steady.
Also check the drives for friction , if so reset and lubricate.
Jan 21, 2013 | Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Washer makes a steady thumping sound
Could be coin in pump hitting blades...Try pump only no spin this will discount the drum ....Check filter if you have one.
Apr 08, 2010 | Washing Machines
I am getting a vibrating noise from my washer right before the final spin. Levleling looks good. This happened a couple days ago. We drained out the water and the washer would work again, but would stop at...
It sounds like you could have multiple issues but a possible cause of the vibrating right before the final spin is a broken shock absorber if one or both are gone it will throw off the center of gravity inside the machine and allow it to move freely and at high speed or even low speed this is not good. part number for both shocks is 134560400. If your machine just stops before the spin cycle and only drains, you could have a faulty door switch. the washer will not spin for safety reasons if this is gone. part number for the door lock switch is 131763245. as well the striker that hits this door switch can be broken and sometime pieces will be left inside the mechanism. part number for the striker is 134456640. The last cause of your washer not spinning could be a motor speed control board, if this is faulty, the motor will not receive the proper amperage to send the motor into spin cycle. speed control board part number is 134409904. Hope this helps.
Thanks
Oct 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
Kenmore dryer works kinda on timed cycle does not work n the automated one kenmore washer also will not spin or drain all the water out of the clothes we just moved so we cleaned it all the hoses and
sound like you have more then one problem
to the drain
http://www.youtube.com/watch?v=Qa6OsgJqLmc&feature=channel
how to unplug the drain
http://www.youtube.com/watch?v=nr6tIO5iNSc
every 2 month is recommend to do the following
http://www.youtube.com/watch?v=2uHyLMWmymM&NR=1
Hope this helpful?
May 12, 2009 | Kenmore 84072 Electric Dryer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Hotpoint VBSR3100D Top Load Washer Logo
165 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
