Question about Microwave Ovens
I purchased a GE Profile Artica frig/freezer Mod.#PSC23PSTB SS; Serial #DM 418474 about 3 yrs. ago. The ice maker is not working. I call a repair man who looked at it and said the "mother board" needed to be replace and also a fan motor for the freezer. He suggested I call you saying that to get a warranty fix that I would have to have a certified GE repairman. I llive in Brentwood, Tn. area code 37027. Question #1: Do I have any warranty that would help with this problem. The repairman said this model is known to have 'mother board' problems. I feel GE should help with this repair. Question #2: Name & number of a local GE repairman
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave vent fan replacement.
The part # SMV-260UA runs just under $60 from SamsungParts, depending on which of three versions you choose. You can find them here.
And a simple Google search shows quite a few hits for "SMV-260UA" and they seem to run about $40, assuming the listings aren't bogus - as so many search results are.
I have a few "new old stock" and used vent & cooling fans here.
I would be happy to supply one whole or just the blades if you like.
Just tell me the dimensions: diameter of the shaft hole and the length and diameter of the "squirrel cage" itself and I'll see if one of mine would work.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Model JVM1870SK04 Spacemaker XL1870
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 12, 2008
vitg55
  • 73 Answers
SOURCE: replacement part needed for GE Spacemaker Micro. (JVM1631BB004)
Appliance online store:
http://www.repairclinic.com/
Posted on Dec 01, 2008
dmftrucker
  • 1922 Answers
SOURCE: Same problem
man i guess so,heck you can buy 3 new top line microwaves for that price,are you mechanically inclined? and do you have a multimeter or can borrow one you can pick one up for about $15.00 and some common household tools?if so lets fix it together,i will help you; my is dan & email is (dmftrucker@yahoo.com
Posted on Aug 29, 2009
SOURCE: i have an electrolux side
I am having this exact same problem. Any answers??????
Posted on Jan 05, 2011
Frig or freeser not cold
If it is your freezer, check to make sure that the air vents inside the freezer are not blocked by food. Putting too much food in an blocking the air vents will prevent the freezer from freezing. Air needs to circulate inside the freezer for it to work properly. This can also cause excess freezer ice collecting on freezer or in foods. Dust and lint will collect under and behind a frig. Pull the frig out from the wall, unplug it. Check for lint under and on the back of it. If it has accumulated some, vacuum it all off and plug it back in and wait a while to see if it gets cold. The fan pulls lint and dust under the frig and it stops the cooling system. If this doesn't work, it may need the freon (can't spell it correctly) stuff replaced. If these don't work, you need to call
Feb 15, 2013 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
I have a GE microwave model# jes737wm02 manufactured inFeb. 2009 it runs but won't cook
we purchased a ge microwave about 2 yrs ago & the paint is peeling on the inside. Is this dangerous & should we continue to use it?
Oct 28, 2010 | GE JES738 Microwave Oven
I have a 21 cubic refrigerator with ice maker. its only 3 years old. just 3 days ago, the refrigerator section stop getting cold. but the freezer still works. i checked out the back of the frig to the...
Inside the freezer, at the back is another fan that circulates cold air from the freeze through out the fridge. Make sure it's running. Sometimes the blade will slip on the shaft and get jammed, or the motor could be defective.
Jun 20, 2010 | Whirlpool Microwave Ovens
According to the GE website I might have a clogged filter which is preventing my icemaker from making ice. they suggest I activate the filter bypass to test the water pressure. I can't find any filter or...
Hmmmm ... do I understand you have a ice maker in your microwave?
I suggest you pull your device away from the wall and look for a external filter or more instructions on the bacck of your ?. There may be a filter inside your (what ever your ice maker is in) .... Can you locate the end of the supply line? Is there a valve on it? If yes. turn the water off, remove the frig end, have someone hold it into a bucket, turn the water back on - let it run for a while. Turn it off. Get a report from your helper about pressure. Check the strainer that may be in the line where you hook the supply pipe to the frig. Make sure it is clear and clean. Try again.
Let me know how this works for you.
Sep 21, 2009 | Microwave Ovens
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
