Question about GPS
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO CHARGE IT. IS THERE A POWER PLUG FOR ELECTRICAL OUTLET CHARGING?
    Sergeant:
  • 250 Answers
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jul 07, 2008
I just bought a used meridian from a source in california i am in virginia how do i get it to iniatilize
Hello.
AMagellan Global Positioning System (GPS) is a car device that determines thebest route from your current location to a destination that you enter. It thenguides you to that destination through voice and visual instructions. Thoughthese installation procedures can apply to all Magellan in general, they arespecific to the Magellan ONE mode
Installing
1 Choose an area by the driver's side windshield, belowyour line of sight, to install the Magellan mount. Make sure your view is notblocked when the GPS is installed.
2 Clean the area with glass cleaner and wait for it todry completely.
3 Remove the protective film from the mount's suctioncup. Moisten the bottom of the cup with a little water so it sticks securely tothe glass.
4 Press the suction cup against the windshield glass.If your model has an Easy Port dial, rotate itclockwise until it locks.
5 Plug the power charging cord into your Magellan andthe power outlet or cigarette lighter outlet of your car.Setup
1 Hold down the device switch for up to 20 secondsuntil a welcome screen appears. If the device does not turn on (the LED lightis not green), it may require recharging. Drive your car for a few minuteswhile your Magellan is attached to the power outlet. Then try turning it on again.
2 Answer the setup questions by tapping the screen. Youcan change your preferences any time after setup by tapping the "ChangePreferences" icon of the "Main" menu.
3 Your device needs to determine its current location,which can initially take up to 5 minutes. Drive your car to an open area withouttall buildings or trees. Put your Magellan on the dashboard console so it has aclear line of sight to the sky. When it determines your position, the deviceshows the driving view.
4 You can now enter a destination by tapping the screenand showing the Main menu. Tap the "Navigate To" button and enter anaddress.
5 Slide the Magellan onto the mount until it clicks.Twist the device slightly until you can clearly see the screen. Begin drivingand follow the GPS directions.
Thanks
Sep 22, 2011 | Magellan GPS
My magellan charges and operates good in my dodge truck, but does not charge or operate at all when plugged into our hyundai or gms Tahoe. Do you have any suggestions?
Try checking if the charger is still working. There should be a light on it if it's obtaining power from the lighter port. On some vehicles you need to switch on the car to power up the lighter port. If it's broken, buy a new charger.
Sep 11, 2011 | Magellan RoadMate 1210 Car GPS Receiver
How do you get started... where do you plug in the gps in my toyota avalon? I have a 5045
Hello, If i understand correctly, you are just trying to set up your Magellan gps into your Toyota Avalon. First of depending on the kit you got for the bracket to hold the unit, it normally will have a suction cup, that secures the bracket, put the bracket on the window, normally to the right of driver view and toward bottom of window, then after putting mounting (suction cup and gps holder) on window, then mount gps in to bracket, now your gps is mounted at this point on window. Now, of course you have to plug it in. GPS kits when you buy them normally have a 110 power plug ( to plug into home outlet) and some will have with the kit, a 12 volt cigarette type of plug to plug in your car (which is 12 volt power) In your home of course you can charge the gps off your 110 power, and gps will run off internal battery for a few hours, but you will find out like with mine, that your better off to plug into car for power, because the internal battery does not last very long. I have a Magellan as well, and they are great units. NOW this being said, if you did not get with your gps a 12 volt car adapter for your gps, you will have to get one. ( unless you have a power converter, which takes 12 volt and converts it to 110 power, but that's another story and only recommended for devices that do not have 12 volt adapter capabilities)
In conclusion if you have the 12 volt adapter to plug in your gps, all you do is find your cigarette lighter, take out your cigarette lighter, put in glove box for storage, and plug your gps in your cigarette lighter, or any other 12 volt cig lighter plugin. That's all there is to it, and now you have power running off your car. Thanks mike , hope this helps
Jul 23, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
My magellan will not charge from my car, only from my hose.
replace the cigar lighter. some plugs like my new phone will not plug in the lighter socket. It may have a broken contact inside the lighter. about a $10.00 repair job.
Deane
Nov 21, 2010 | Magellan RoadMate 1412 Car GPS Receiver
Won't turn on.
if you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
May 06, 2010 | Magellan Maestro 4040 GPS Receiver
Magellan Roadmate 2200T -dark screen
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | GPS
It is shutting down while we are using it. it is plugged into the lighter outlet and has power, does not show a low battery
try a hard reset first using a paper clip, innsert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update off the magellan site..you must register the unit with magellan before you can download the update.
Jul 29, 2009 | Magellan RoadMate 1430 GPS Receiver
Gps will not turn on
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
you can email me through here or email to.... wmetz@comcast.net
Jul 18, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
Jun 08, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Just want to know if I should have the magellan on when it is being charged. Maybe it will not charge unless it is on.
turn the gps on and go to the system screen, go to the power option and see if the green lights are blinking. then set the power to turn off in 10 minutes. the gps will go in stand by till the unit either moves or you hit the power button again. if you have a charging problem on your magellan, i can help you get it fixed.
May 30, 2009 | Magellan Maestro 4040 GPS Receiver
GPS Logo
1,213 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
