One of my AC units froze up. I cut the unit off. after it defrosted I turned it back on soon after we smelled wires burning. I turned the unit off. Now when I turn the unit on the outside comp. goes on but the air handler will not turn on , I checked the low volt fuse it is fine and ther is no reset switch, what could have happened there are no burnt wires inside the air handler.
    Novelist:
    Champion:
  • 230 Answers
You may have a couple of problems now. The original issue of icing up is most commonly due to low refrigerant in the a/c. For this you will need a professional to correct.
The second problem sounds like it may be a bad capacitor for the indoor blower motor. This is a common occurrence after a system freezes. Often the water that leaks from the A/C will get slung around by the fan causing the water to cause a short on the capacitor. The capacitor is a silver/gray electrical component that usually stands alone from the rest of the circuitry. It is cylinder shaped and has two wires (usually brown) connected to one end of it. It is common practice in the business to replace both the motor and the capacitor after this kind of water damage.
Posted on Jul 07, 2008
Help!! Bad Smell coming from AC/Heater will driving but when idle no smell from under the hood.
Sounds like the volatile fluid gas that is used in the refrigeration of the ac unit has leaked or it needs resealing and regassing.most garages with ac repairs techs will know this.Its about £75 in uk money to regas such a unit.did the air conditioning unit not work as well during preceding weeks is a sure telltale sign it needs regassing.good luck.
Jan 16, 2015 | Chevrolet Cars & Trucks
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
I have 3 central ac units for my house. 1 for the upstairs and 1 for the west side of house and 1 for the east side of house. just had a very cold night and the east side of house vents smelled like...
To make sure that there is not a problem with your blower test it on cool. if it runs good. then start the heater on auto and it should be okay. but still supervise the operation for about 5 mins. if you still smell something burning . then call an AC Technician for help.
Albert Saavedra
AC Technician
Fort Worth/Dallas TX
773-627-8766
Dec 28, 2010 | Heating & Cooling
Car turns off if ac or window deforst turn on even low setting
Well, The problem seems to be the AC unit. When you activate window defrost the ac unit also activates for some reason. Disconnect the wires from the AC unit and turn on the defrost, if the engine doesn't stop then you know that is the problem, if it does die then you have a vacum problem.
Oct 09, 2009 | 2003 Ford Focus
Duo Therm 57915.541
Since you have a knob, I am assuming that this unit has manual controls that are mounted directly below the air conditioner on a ceiling pack. If you smell burned wiring, remove the inside shroud to access the 120VAC connections in the unit. Check these connections for OK, if they look burnt, cut them back and reattach them (be sure to turn the breaker off first). Try the AC again.
If those connections look fine, then remove the upper cover from the unit. Access the capacitors on the side of the unit and check them for ok. If any one of them looks burnt, replace it. These two places are usually the only place that you will get a burned plastic smell.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
A/C hums, does not kick on
Sounds like you have either an bad Start Capacitor/PCTR or have burned out the controls of the front unit. Get on the roof and remove the upper shroud of the front unit. Access the capacitors by removing the cover on the side of the AC. The capacitor that you are looking at has a black "relay" attached to it. Visibly inspect this for electrical damage or charring. If so, replace it. If this looks fine, then put everything back and head inside.
Remove the inner shroud from the AC and pull down the control box. Remove the cover from the control box and inspect the 120V connections for ok. If they are burned, you can often cut them back to clean wire and reattach. If these look fine, remove the entire cover and inspect the 120V wires at the relays. If they are burned, replace the control unit.
Hope this helps,
Jeff
Jun 25, 2009 | Dometic Rooftop RV Air Conditioner
Burned electrical smell from the freezer compartment
I would check the defrost thermostat usually a button type switch with 2 wires on it mounted to the freezer coil. Size depends on type ; 1 type is about quarter size, 1 is about dime size, and electronic sensor (not had one burn out but the board could smell like your description but I believe these are not in the freezer section).
I have had these cook out and smell up the freezer section before. And if they go out guess what it wont defrost either. If your fan motor goes out it might smell and wont cool all over but the frost should be minimal.
Also a bad defrost heater could make a smelly situation it is usually a black rod or aluminum colored and the rubber ends can burn and make a smell.
If you find its the heater, I would replace the defrost thermostat as well. Its suppose to cut off the heater before it gets too hot.
If this helps you find your problem please rate me as high as possible if not please post back with more information as to what you did find. Thanks for using fix ya and good luck.
Mar 29, 2009 | Kenmore Refrigerators
Bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Oct 31, 2008 | Sharp CV-P09FX Air Conditioner
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
