Question about Home
Bathroom Heat/vent/light combo has failed G4A00, found source @ http://www.goodmans.net/list.asp?d=632&sc=goog&k=g4a00%20thermal%20fuse&gclid=CMrkoqaJkqYCFa1d7AodkHJgng. This page lists various TF###C values for G4A00s, where ### = Thermal Factor in degrees C. You may have to justify cost of shippng VS replacement cost, but if you are comfortable making electrical repairs, here is a source for this part.
ctf1800
  • 4402 Answers
SOURCE: samsung hcm4216 rear projection
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Posted on Dec 18, 2007
Inky
  • 691 Answers
SOURCE: Magicolor 2300DL Question?
IF memory serves me (I have Alzheimer's you know!!!!!) the part number is 9321-2100-41 SL1 Take Up Solenoid.
If you need a copy of the service manual for the Konica Minolta (QMS) 2300, you can download it here:
http://www.tradebit.com/filedetail.php/3278096-Documents-eBooks-Technical
Posted on Aug 14, 2008
  • 19 Answers
SOURCE: Will a DDR Ram work with a DDR2 Video card?
The on board memory on the graphics card being DDR2 will NOT affect the system memory being DDR.
And the memory you want to add depends on the memory you have allready installed on your machine and what version of windows you are running.
Please post back with more info on this.
Posted on Dec 30, 2008
dsacco86
  • 1077 Answers
SOURCE: trying to find out what parts needed to fix panasonic th-42pz80u
If your TV model is TH-42PZ80U, and you want to replace the whole power supply unit, shopjimmy.com has them for $160. But for each parts# on that board itself, you need to find a Service Manual to look up that part.
Posted on Feb 02, 2009
SOURCE: Cannot display page, link http://www.yahoo.com/r/m2 failes
tried to display another web page no luck...turn off firewall and see if it was blocking web page no luck...
Posted on May 02, 2009
I have a washer dryer combo DWC LD1013 it stoped drying. My clothes are more wet when put in to dry. The clothes would be extremely hot but all wet. It works 1 cycle and then stops. Please help ????
In order to dry cloths, you need two things, heat source and air flow. Sounds like you have heat but no air flow. If you can, pull unit out and check vent for washer. Look around unit and make sure there is nothing blocking any vents. If you don't see any thing, try drying with vent not installed. I run into a lot of homes with clogged vents inside walls. By drying with no vent installed, it might tell you if you have dryer problem or a home issue. Good Luck
May 25, 2016 | Washing Machines
Ac comes out heat vent
I would say the blend door is stuck or something happened to the selector on the dash. The system uses engine vac to move the blend door and direct air flow. If the vac source fails, the system is supposed to default to the defroster position.
Jul 15, 2012 | Chevrolet S 10 Cars & Trucks
I have a Kidde combo CO / Gas monitor. The last two mornings at almost the same time (7:00 AM) the alarm sounded with the word GAS displayed. The condition went away in about 30 seconds each time and the...
Besides the obvious jokes about gas in the bathroom, I would advise you move it out of the bath room. It is being affected by excessive moisture causing errors in the sensors. The same can happen for smoke alarms with condensation or other moisture sources. It should be located relatively close to a possible source of problem, but not right on top of it.
Is the shower in use at around 7 am every AM?
Nov 10, 2010 | Kidde Nighthawk Combo Gas/co Detector
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
How do you access the light on a broan fan/heater/light? This is a ceiling unit in a bathroom. It is a vent fan/heater/light combo.
Gently pull down, work it down slowly these tend to get dry over time and crack, If you do not see any exposed screws it is the basic pull down type. Not to insult your knowledge but make sure the fan is not on when you do this because the blades will be exposed.
Oct 09, 2009 | Dryers
TRYING TO FIND THERMAL FUSE. MICROTEMP G4A00 TF216C
Unfortunately, YoTeach's initial solution is in error, I believe. YoTeach mentions that typical temps for brewing water are less than 200F, and THAT seems OK, from a couple of quick searches.
However, the component that is being replaced is not necessarily working at the same temperature as the water needs to be.
The Microtemp G4A00 series has lots of temperatures, and the TF216C means, AFAIK, that Tf is 216C(elsius). See, for example, the datasheet here:
http://www.farnell.com/datasheets/625786.pdf
Tf is the temperature at which fuse opens. So, the person ACTUALLY needs a thermal fuse that opens (breaks the connection) at 216C.
Therefore, either of the two fuse temperatures mentioned: 128 & 140C, would open too soon: i.e. at too LOW a temperature.
While 216C may seem like a high temperature (420F), for the fuse to open, the thermal fuse is often very near the heating element. For comparison, I have a Gevalia CM500 coffee pot, and the thermal fuses in my particular unit are Microtemp G4A00 184C- which is about 363F.
If anyone thinks I am in error on this, please feel free to contact me: jim underscore peak at Hotmail dot com - and I'll be happy to correct this post.
Aug 29, 2009 | Krups Small Appliances Espresso Machine
Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Jul 19, 2009 | Broan-NuTone N-8663RP Combination Light...
Home Logo
149 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
