Question about HP Color LaserJet 2600n Printer
I'm printing on 110 lb card stock and the toner gets crispy..and actually flakes off on the edges and sometimes leaves smears and clumps of black or burnt toner on the paper. It prints fine on 20 lb paper but just started putting a grey cast over the entire page. I have been using remanufactured toner cartridges but both problems just started happening. Is this a fuser problem? any help appreciated!! lnoltee
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
Could be the fuser but there is a setting for heavy paper or card stock which will slow it down and increase the heat. depends on your model as to where this can be changed.
Posted on Aug 02, 2017
EPIJAB
  • 89 Answers
SOURCE: hp laserjet 2200d
If the toner smears after the page comes out of the printer you may need a new fuser. The fuser is the heating unit in the printer and can usually be seen from opening the back door. Check and see if it has a line worn down the same side as the mark on your pages.
Posted on Feb 15, 2008
SOURCE: Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Posted on Sep 18, 2008
  • 34 Answers
SOURCE: My HP1020 prints black shade throughout the page
You have bad toner or a bad toner cartridge. Get a new cartridge.
Posted on Mar 12, 2009
SOURCE: hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
Posted on Apr 05, 2009
  • 71 Answers
SOURCE: HP 4550 Color Laser jet reports no "errors" yet does not print
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Posted on Jul 21, 2009
I have an oki c9650 when I print on cardstock the blacks become bubbly and flake off, but only when printing on cardstock
Set it or computer, whatever you are using to cardstock, or it may be called thick,there are multiple selections depending on the media. Beacuase thick paper requires slower speed and hotter fuseing.
Sep 26, 2012 | OKI C9650HDN Led Printer
Left edge black on hp laserjet printer
Fuser teflon sleeve got damaged, replace it.. (only professionals can do this activity) if its not available go for new fuser assembly..
Jul 31, 2012 | HP "LaserJet P2035n Printer"
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
Toner flakes off of cover stock
The fuser on fax machines is set at a temperature to heat 20 lb paper hot enough to fuse toner. Cover stock requires more heat or a slower passage through the fuser. This is done in copiers by setting the paper type to thick, which slows down the paper passage. Check if there is a setting in your fax for a different paper type.
Nov 23, 2009 | Office Equipment & Supplies
Print Quality problem Xerox 7400DN
Opening a cover during printing will cause a paper jam. If you do this several times and carefully clear th paper you may be able to isolate the origen of the smudging.
Jul 17, 2008 | Xerox Phaser 7400DN Laser Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
Help with Brother MFC-8500 all in one printer
When you get the paper, can you smear the print with your fingers, or is printed on there properly.
if you can smear it, it would be your fuser not doing its job properly, if you cant, then its your replacement toner as it most likely incorporates the drum in it, which i think is your problem.
Jun 20, 2008 | Brother MFC 8500 All-In-One Laser Printer
HP Color LaserJet 2600n Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
