Question about Maytag Neptune MDE5500AY Electric Dryer
Control panel lights up, but won't start when button is pushed. problems stated gradually, would start after breaker was reset, but now quit entirely. wife thinks it is the start button, but I'm thinking that maybe door closed lock button? start button feels fine, not defective. Help Me Please!
  • Maytag Master
  • 43,501 Answers
Either one of you could be right... or neither of you...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My appliance is just 6 months old. The panel is on the top.Push buttons, I can get it started.
In most cases this is the control panel that is bad. It should be covered under warranty.
May 04, 2015 | Whirlpool WDF530PAYB Full Console...
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Feb 13, 2013 | Microwave Ovens
My dishwasher won't turn off. It sounds like it is humming - like the drying cycle - no water is going through it. Even when we open it and push the off button, it continues to hum. We had to turn...
Most dishwashers do not have a 'reset' button other than the on/off switch. It would seem that you have a problem within the control panel if it is a computerized model and it is usually best to have a service call to test for this.
If the unit is fairly new, check the manual to be certain that you are not missing a step somewhere.
Oct 02, 2017 | Asko D3531XLHDSS Stainless Steel Built-in...
I just finished cleaning my swimming pool and tried to switch on the water pump but nothing happened.Then i noticed that the red trip light on the control panel was on. What do i have to do to fix this?
hi! there,
open the control panel,besure to close circuit breaker first,on control panel there is a over load protection relay,push the reset lever,then close the control panel,switch on the breaker and push the black push button to start the pump,observed if trip off again,check the cathridge filter,replace filter because the differential pressure
was exceeded the set up on pressure switch.have a nice day,don't forget to rate me,thank's
Apr 23, 2009 | Home
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Maytag Neptune MDE5500AY Electric Dryer Logo
47 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
