Do you have a free luxman r3030 owners manual ?
HOW TO REMOVE #18 RING
With a very thin screwdriver or with a sharp tip of a cutter the bevel on the ring bounce out of the groove and rotating and work the ring out of the groove
Jul 18, 2015 | Ridgid R3030 Contractor Tool Bag
How do I take apart a Ridgid R3030 reciprocating saw
scroll down to the bottom of the page on the link, it gives you some dismantling instructions.
Ridgid R3030 One Handed Fuego Reciprocating Saw Parts
you may be able to order your parts here.
RIDGID R3030 Reciprocating Saw Parts
Jan 31, 2015 | Ridgid R3030 Contractor Tool Bag
Turntable manual for a luxman p-400
Hi, any phono pre amp will do it. The better ones have RIAA with gain control and earth point. Cheers john. Stylus City
Feb 23, 2014 | Audio Players & Recorders
Luxman turntable manuals
Have you tried the Luxman website? Most makers have free PDF's of them.
How can I correct error Code E602-0001 on my Canon copier?
You can try to reflash the hard drive or replace the hard drive
Sep 27, 2010 | Canon imageRUNNER C3200 Copier
LUXMAN L-85V AMPLIFIER LOW VOLUME
Make sure that you have the turntable connected to the PHONO input. If there is none (I don't know your specific model), then you will need a phono pre-amp. Connect the output of the pre-amp to tape-in or Aux in and the unit should work as expected. The alternative is that you may have the tape monitor turned on. Check that as well.
This unit is old enough to have pre-out and amp-in connectors on the back. Make sure that those are connected to each other. Use standard RCA cables.
If none of those resolve the problem, there is an internal problem that will need a bench to resolve.
Dan
Oct 26, 2009 | Audio Players & Recorders
Luxman Digit synthesized stereo Receiver AM/FM & Phono not work'g
The problem is still there, but I am expecting HELP fir free.
May 11, 2009 | Car Audio & Video
Blown output drivers
The transistors are 2SK405 and 2SJ115.
I fix Luxman if you dont mind sending to Vermont.
Cheers ( I hope that helps)
Feb 14, 2009 | Alpine Audio Players & Recorders
Owners Manual Replacement
Check out this web site http://www.audiocircuit.com/index.php?c=LUX&cc=940&m=D-351# Looks like they will be able to help you.
Feb 14, 2009 | Classic Electronics Audio Players &...
59 people viewed this question
 Grubhead
Grubhead
