Question about Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
  • Hotpoint Master
  • 3,463 Answers
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Posted on Dec 29, 2010
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
Wma76 spin and door lock issues
Most likely a motor control issue or possibly the motor itself
Oct 30, 2017 | Hotpoint WMA76 Front Load Washer
No spin cycle
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Shane
Shane
Mar 01, 2011 | Hotpoint WMA76 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 Ultima 6kg
either you got a clog behind the drum or a clog in the draining tube behind the washer i would call sears or where you got it to get someone out there to check it out or if you got the manual of the washer and specs to see maintenance tasks that it requires if you know the make and modal i could get that for you ..
djkb
Jun 26, 2008 | Hotpoint WMA76 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hotpoint WMA76 Front Load Washer Logo
327 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
