Question about Garmin nuvi 200W GPS Receiver
I have a nuvi 200w. it powers on but then hangs on the garmin logo screen. it never moves off this. i have tried master reset (hold power for 8 - 15 seconds) but this does nothing. i have also hooked it up to the USB in the hope that its a software issue but nothing happens. there is no reset button and i cant take the battery out without taking the back off. help! thanks in advance ben
  • 1 more comment
  • benjiboy71 Jan 02, 2011
    Hi Walesaruni
    Thanks for the above, but I have tried updating the software and it hasnt worked as it falls at the first hurdle. The PC does not load any drivers and the GPS doesnt change from the homescreen of the garmin logo.
    i have tried resetting (holding for 8-15 seconds) and nothing happens. It just sits on the garmin logo screen and every now and then flicks off and then back on again.
    Any ideas?
    Thanks
    Ben
  • benjiboy71 Jan 29, 2011
    hi
    i tried that and it did give me a new message i hadnt seen which was 'system software missing' but when i downloaded the web updater it says some devices were found however the necessarry capabilities are missing (i imagine as there is no software on the device)
    it says to switch it on then try again but this doesnt work.
    any more ideas? thanks for your help with this by the way. appreciate it
    ben
  • benjiboy71 Feb 24, 2011
    hi walesarumi
    as you are the only person on here who seems to know anything about this do you have any more ideas on what i can do to get this fixed? its driving me mad.
    fingers crossed
    thanks
    ben
  • Garmin Master
  • 6,993 Answers
the problem is actually a software issue and since resetting does not solve the problem,I think updating the deice should solve the problem. Update is just like reinstall the system software of the unit and it might get things fixed.
To perform update, follow the below procedures;
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web address: http://www8.garmin.com/support/collection.jsp?product=999-99999-27
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Good luck.
Posted on Dec 31, 2010
  • Walesarumi
    Walesarumi Jan 02, 2011
    updating is the surest way of fixing this problem, but obviously, the problem is how to connect the GOS to a computer so that it would be recognized. But i have found a trick that might be help.
    With the unit OFF, hold your right thumb on the Upper, Left part of the
    screen and plug the USB plug from your computer into the back of your
    GPS. The unit should boot up and stop at the screen where it shows a
    little computer, wire, and little GPS. Your computer should now show the
    GPS as connected. Only now you can pull your thumb from the screen.
    Then use Webupdater to upload 4.40 to your GPS.
    Hopefully, the above should be helpful this time around.
    Good luck.
  • Walesarumi
    Walesarumi Jan 29, 2011
    Okay!
Garmin want turn on
Try a master reset and also check if the USB is loose in the back. If so, the battery will not charge and an external charger will not work.
Master reset is accomplished by holding the power switch to the left for 10 seconds. Also look to see if there is a reset flap area on the bottom where the label is.
Sep 17, 2013 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 255W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 255W GPS unit.
I hope that helps.
______________________
Backup & Restore Nuvi Favorites here.
Download Nuvi 200W Manuals here.
Download Garmin WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Garmin Nuvi 200W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
You have now performed a hard reset of your Garmin Nuvi 200 and 205 series GPS unit.
I hope that helps.
on Apr 18, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 40lm stuck on garmin logo
Following the instructions, at the following link, fixed the problem with my NUVI 40 - http://support.garmin.com/support/searchSupport/case.faces?caseId={4a78cf80-fce4-11e1-e8a7-000000000000}
Jul 22, 2012 | Garmin nuvi GPS
My Garmin nuvi 200W has had a battery recall and replaced by Garmin. It powers up OK and locates OK but hangs after approx 0.5-1 hours. I cannotr even turn it off without pressing reset. I have updated the...
Send it back to Garmin. The fault may be coincidental, but unless you fancy buying a replacement model it's worth seeing what Garmin have to say. It should only have been a straightforward battery swap, but if the technician forgot to wear an earthing strap it's entirely possible that a component suffered static discharge damage.
I've been holding back from sending my nuvi 770 in as the battery seems fine and I've often had problems with shoddy recall work on digital cameras and similar devices in the past.
Sep 22, 2010 | Garmin nuvi 200W GPS Receiver
My garmin nuvi can not find sterlites can you advise please. all else works fine , i have not updated since i bought it some 12 months ago ? i have tried the reset button but still the same . it has asked...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First try a MASTER RESET:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1200,1300,1400 or 1600 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
If that doesn't work.......
THEN FIRST make SURE you have the latest software in YOUR computer and in YOUR Garmin.
You can get that FREE at Garmin here:
Normal 0 false false false MicrosoftInternetExplorer4 To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps
Does this help? Let us know. Thanks.
Oct 15, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200w Flashing screen "Garmin Logo" will not turn off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Do a RESET:
The reset button on your nuvi 2xx, 3xx or 6xx will not restore your device to factory settings or delete any map updates. The reset button will switch your device off if you are unable to switch the device off by the power button. It will not erase any data on the device.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin nuvi 260 is only 6 months old and it can
First make sure you have the latest software in it.
If it does try a Master Reset.
Lastly, unless you're in a strange location with poor reception. Take it back. Or, it's still under warranty.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on your nuvi 260 series device:
  6. Touch Yes
Aug 04, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Unit Cuts Off
Sent unit back to Garmin.
Apr 02, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
52 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
