Question about Yamaha RXV367 Receiver
Why does my Yamaha receiver control the power for all my components - when I turn off the receiver all my components turn off (or won't turn on when the receiver is off)?
  • mhkerr Dec 29, 2010
    I do have my cable box and TV running with HDMI cables, but my DVD player is still on component cables and it also turns off. If it results from using HDMI cables, how do I watch TV (cable) without turning on the receiver?
  • 10,594 Answers
This will happen when connection setup is through HDMI cables between all components. Turning off one thing will turn off all connected things in that setup.
This is not problem, in fact it is feature because HDMI cable has control signals as well including video and audio signals.
Hope these info will help you.
Let me know if connection setup is different or I missed any thing.
Thanks.
Posted on Dec 29, 2010
  • Shahid Electronics
    Shahid Electronics Dec 29, 2010
    where from dvd player getting AC Power?
    you can watch cable channels by unplugging receiver from AC power socket, this will disable HDMI connection in receiver.
I have a Yamaha RX-V861 that has worked perfectly for years but now I am having an issue. My LG TV makes a popping noise and turns off. It does this 5 or 6 times and then everything works normally. My
If your unit has HDMI Control turn it off on your Yamaha but if it does not have it and your TV does then turn it off on your TV. You can test that theory by unhooking the HDMI cable and using any of the other forms of video output your Yamaha supports, so if you hook it up using component cables or even composite cables we know the problem is coming from the HDMI and the above steps should fix that. Good luck.... http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=8128
Oct 20, 2014 | Yamaha Rx-v861b - Av Receiver - 7.1...
Setting up my rx v2400 to my tv
The setup may depend on your TV and other components and how you plan to use the system. Does your TV have analog or digital audio outputs? The receiver has analog and both types of digital inputs (coaxial and optical).
Use the best cables that you can. You can get all cables at online cable stores for much less than at the electronics big box stores. I'll assume that you already have the speakers connected to the receiver.
Next you can either connect your devices (cable box, blue-ray player) the receiver's inputs. Then connect the receiver's video out to the TV. This is great if you will only listen to the devices with the home theater system. Then you can also connect the TV audio out to the receiver for the OTA TV audio. For this you probably need component video cables and audio cables. These are all cables with RCA plugs.. Then get another audio cable for the analog or digital optical output of your TV. For some TVs the only audio out is the headphone jack. In that case, you also need a 3.5 mm to RCA adapter (the simplest is 3.5 mm M to RCA F/F for connecting to an RCA audio cable). For this method, you won't have to turn off the TV speakers most of the time; the TV won't have any audio.
Alternatively, connect each device audio/video out to the TV's input and then only connect the TV's audio out to the receiver DTV audio IN. Since the receiver doesn't have HDMI, this is the best option if your devices have HDMI out. For this, use the appropriate number of HDMI cables and the analog or digital optical audio cable from the TV to the receiver. Then turn off the TV speakers and enable the external speakers in the TV menu. You can connect to any of the receiver's inputs. If you use the labels, you'll find it easier to turn on the inputs.
If you have any devices with composite video output, use the same basic steps as for the component
The documentation for the RX-V2400 is available at the Yamaha product site: http://usa.yamaha.com/en/products/audio-visual/hifi-components/stereo-receivers/rx-v2400_black__u/?mode=model . You'll need to be a registered Yamaha user (Easy-Pass) to read the manual online.
I hope this helps. Please add a comment with your devices (including the model of the TV) for more specific information.
Feb 19, 2012 | Yamaha RX-V2400 Receiver
Since our downstairs circuit tripped due to an oven heating element fault, my Yamaha HTR-5740 won't turn on. The unit was not on at the time and the power supply is working fine.
it is possible that the standby power supply circuit has become defective in the receiver...this power supply supplies power to the remote control and microprocessor even when the unit is off...this is so it can pickup the remote signal when needed...this supply consists of a small transformer and associated regulation components...it may be possible that the power surge sent when the element overheated n kicked the breaker that the small transformer may have an open primary..or it may just be a fuse for this supply...you can remove the cover of the unit and look at the small glass fuses...you may have to remove them to see if they are defective...remember to only remove them one by one as you do not want to put them back in the wrong place...if it's not a fuse..then more likely the transformer has opened up...you will need to have the unit serviced by a qualified service person
Jul 17, 2011 | Yamaha HTR-5740 Receiver
My comcast remote won't turn on or off my yamaha rxv365 audio receiver only controls the volume the code i put in was 30176
It controls the volume just fine. It's the power that doesn't work. I'm having the same problem with my Yamaha receiver. Different model. Multiple Comcast remotes too.
Apr 14, 2011 | Yamaha RX-V363 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
May 01, 2007 | Yamaha HTR-5990 Receiver
Yamaha RXV367 Receiver Logo
147 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
