Question about Invicta 8937 Wrist Watch
How do I replace the screwdown stem and crown on my invicta automatic watch?
SOURCE: watch crown
Dongguan Perfect Watch Parts Co. , Ltd. has been manufacturing and selling the watch parts-crown for nearly 5 years since 2002. And we have many different materials crown & pusher for our customers. Such as, stainless steel, copper and alloy. BTW, In order to suit our customers' requirements concerning the environment protective, We also provide our customers crown&pusher which meets RoHS compliance .
Tel:86-0769-21295490
Email:Cruiseju@gmail.com
Posted on Oct 14, 2008
  • 108 Answers
SOURCE: How do I remove the crown/stem.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder.
Posted on Apr 04, 2010
Testimonial: "thanks"
escapement
  • 2334 Answers
SOURCE: i pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Posted on Mar 24, 2009
  • 93 Answers
SOURCE: My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Posted on Nov 03, 2009
disap1
  • 98 Answers
SOURCE: Stem falls out
It can happen to ANY watch! Take it to a reputable watch repair shop and let them fix it....just needs some loctite but the stem needs to be removed from the movement so the crown can be correctly put back on!
Posted on Jan 15, 2010
Need help winding an Invicta 14214 russian diver automatic
once you have removed the screw down cap there is a smaller crown , looking at one of these before the smaller crown can need a bit of a tug to pull out maybe even a pair of pliers.
Nov 19, 2017 | Invicta Watches
How do I set the time on an Invicta Pro Diver watch?
Depending upon the movement, most pro divers have a *****-down crown for water tightness. First unscrew the *****-down crown. You can then pull the stem out one or two clicks. The first click permits you to set the date by turning the crown one way or the other. The second click should permit you to adjust the time. Then push the crown back in, hold it down and ***** it down 4 water resistance. Be gentle when manipulating the crown and stem!
Nov 02, 2015 | Invicta Diver Watches
How do I change date on my Invicta 7352 ?
Usually, after unscrewing a *****-down crown, pulling the stem out one click will allow the date to be advanced by turning the crown in one direction or the other. Depending on the movement, a clockwise turn of the crown may advance the date and the counter clockwise turn might advance the day of the week, for example.
If all else fails, pull the stem out two clicks and advance the watch hands 24 hours for each day you wish to advance the date.
Jan 13, 2015 | Invicta Signature II Series Watch 7300
How to wind up an invicta
Unscrew the crown by turning it counter clockwise until the crown is free from the stem. Then turn it clockwise six times. After this step push the crown in and continue turning it clockwise until it is once again screwed back on to them stem. DO NOT SKIP THE LAST STEP because although the watch will operate in the winding position it no longer water proof. A simple drop of water in the stem would mean death for your watch. If you wear the watch everyday I suggest you wind it once or twice a month.
Jan 01, 2014 | Invicta Watches
I HAVE AN INVICTA PROFESSIONAL AUTOMATIC MODEL 3744 GIVEN TO ME BY MY SON.HOW DO YOU SET THE TIME ON IT? DOES THE STEM PULL OUT TO SET OR DOES IT UNSCREW? THANS
I was not able find information on your specific model; only 2010 models seem to be listed on the website.
Instruction Manual for Invicta watches:
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
Go to page 8 of this file to identify the instructions for your watch. For most watches the crown pulls out for setting either to postion 1 or position 2.
Some Invicata watches do have Screw Down Crowns but this would be most likey on a Diver model, to help prevent water infiltration. In order to adjust the date and/or time on such a watch, you must first unscrew the crown before you can gently pull it out to its first or second click stop position. To do this, simply rotate the crown counterclockwise until it springs open. When you have finished setting the watch, the crown must then be pushed in and screwed back in tightly. Not doing so will cancel the water resistance of the watch and will void all warranties from the manufacturer.
Mar 21, 2011 | Invicta Watches
I have an original Invicta Men's Lupah w/ chronograph. Which of the 3 buttons on the side of the case is for setting the date? I can't seem to figure out how to set/reset the date. Thanks in advance...
If your lupah has a screwdown crown (middle button), you need to unscrew it. Pull out the middle button 1 click (it should have 2 clicks...if it's all the way pulled out, then you have gone too far) and turn the screw counter clockwise. Some model's you have to give them a couple good turns to adjust a single day, so don't give up if you move it a quarter turn and nothing moves. Once done adjusting, just push the crown back in and lock it down (lock down crown isn't a necessity. It is rather a means of keeping water at pressure from entering your time piece. So don't freak out if your model doesn't have a screwdown crown. Not all of them do). Best of luck to you!
Jun 14, 2010 | Invicta Dragon Lupah 2094 Wrist Watch
I have a Croton watch. It is a automatic.I can't get it to run.I was informed that the watch had to be wound. The crown{stem} has four settings.I shak it and it runs for about 15 seconds
In the first position (closest to the case but not screwed down if it's a screwdown crown) wind the crown clockwise about 40 turns and it should run fine. The automatic winding system relies on wrist movement to spin a weighted rotor that winds the watch. When you're not wearing the watch or not moving much when you do have it on, it will run down and you have to manually wind it to get it going again. If you wear it everyday and are reasonably active you may never have to wind it but take it off for a day and you will.
Apr 20, 2010 | Croton Automatic Watch Day/Date Swiss...
Stem falls out
Jan 13, 2010 | Invicta Watches
I cannot set the time or date on my watch. The
Hi Frank
Does the watch have a 'screwdown' crown on it or pull out crown (also known as a dust proof crown). A screwdown is usually on a model which has a waterproofing of around 100 meters (330ft) +
To change the date ( the quick way usually but not always) GENTLEY pull out the crown (or first unscrew if it's a screwdown) to the first 'click' you will feel it. then gentley wind the crown down towards the six or up to the tweleve (some change mostly its down towards the six) and Hey Presto the date changes automatically. This beats winding it through 24 hrs.
Now to change the time, from the date set one more gentle click, or two from the original (standby position). then you are free to move the hands as you please.
Hope this helps Frank
Jul 13, 2009 | Watches
Can't pull out knob on side of watch to change time
You may have screwdown crown. Try to unscrew it first and then pull out. If the crown is turning but you can not pull it out, there is a rust in the watch and you will have to find your nearest watchmaker to sort that.
Rate, please.
Mar 28, 2009 | Invicta 2636 Ocean Ghost Chronograph Watch
Invicta 8937 Wrist Watch Logo
2,068 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
