Question about Whirlpool LSR7333 Top Load Washer
For a whirlpool washer model LSR7233EZO. The agitator no longer moves at all. What part(s) would need to be replaced?
  • 183 Answers
SOURCE: Whirlpool Washer LSR8233EQO
either motor faulty or if mtor is running then the flexibla coupling between the gearbox and the motor is faulty. Regards Advisor
Posted on Aug 22, 2007
mikedurland
  • 481 Answers
SOURCE: Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Posted on Jul 15, 2008
docjohn174
  • 943 Answers
SOURCE: WHIRLPOOL TOPLOAD WASHER LSR7233EZO
hithe part you need to replace is called a drive coupling which goes between the motor &transmission you have to remove the cabinet to get to this part if you tip the washer towards the wall and look between motor ant transmission to remove the cabinet 2 screws at the console where cabinet meet lift console 2 brass clips 1 each side spring clips screw driver in cavety and pry remove cabinet 2 clips on pump remoce 2 screws on motor remove 2 long metal clips on motor disconnect wiring from motor remove 2clips from remove motor replace coupling thanks the appliance dod
Posted on Sep 17, 2008
abhishek33
  • 1239 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Posted on Jan 07, 2009
  • 130 Answers
SOURCE: Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Posted on Jan 26, 2009
I can't remove the agitator on my whirlpool washer model #lsr7233ezo
Watch this youtube video the FIRST 40 seconds of it will show you how to do that
http://www.youtube.com/watch?v=0GQh8JLqVv8
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Washing Machines
WHIRLPOOL MODEL LSQ8543J TOP AGITATOR DOESNT MOVE. THE BOTTOM AGITATOR MOVES FINE DURING THE WASH CYCLE BUT THE TOP AGITATOR HAS STOPPED MOVING. HELP!!!!! WHAT COULD THE PROBLEM BE????
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the proper inspecting and replacement of these parts. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Wtw6300sw1 agitator moves clockwise no counterclockise mov
This sounds like the dogs need replaced in the agitator. It's relatively easy and inexpensive to do.
Feb 11, 2010 | Whirlpool LSR5132PQ Top Load Washer
The tub on my whirlpool washer fills with water but will no spin
If the washer will fill and drain, but won't agitate or spin, this is usually a sign that the motor coupling has broken. The noise of the motor engaging, lack of agitation and ability to still drain are common symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you have questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Sep 25, 2009 | Washing Machines
The upper agitator on Whirlpool Model LA9100XTW1 is not rotating
To repair agitator remove the top of it < snaps on> then remove bolt from center and the agitator will split in middle. You'll find a center cogg with three arms remove this and replace with new one< the kit that you described is this part > and assemble it.The coggs are move freely to engage so you don't have to align them in any way.
Apr 22, 2009 | Whirlpool Washing Machines
Top of agitator not conncted to bottom
not quite sure as to how your agitator is nol onger connected??? but i looked up by model number and you can order and replace the complete agitator for about $50... ifhte agitator no longer "agitated" and was reemoved to replace teh agitator dogs (which is the most common issue) the the 2 halves of the agitaotr click back together by lining up slots betweeen the two halves.hoping this was a little helpful
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Water leaking into tub
This sounds like a bad water valve. Replace the water valve and it should stop the water leak.
Jan 20, 2009 | Whirlpool LSR7333 Top Load Washer
Whirlpool GSQ9632LW0 problem
looks like the agitator dogs are broken. these are the pieces between the bearing and the top of the agitator. since this agitator is a 2 piece, you can just replace the dogs.
go to www.whirlpoolparts.ca and put in your model #. it will give you a parts breakdown.
hope this helps.
c
Sep 23, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool LSR7333 Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
