Question about Maxtor OneTouch 4 Mini 120GB External USB 2.0 Hard Drive
My computer says it does not recognize the external hard drive after i have used it for several months. If i use it on another computer, will it recognize it or should i download something first?
    President:
  • 1,812 Answers
Install the hdd in another PC, If run well,think your OS has corrupted.
Then you should re install the OS again.Or you can restore the system
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If the HDD is not run run in that another pc ,think external hard drive, has damaged and should change.
Hope it will help you.
Posted on Dec 29, 2010
Drive lights up but cannot see it on computer
The drive may most likely be dead. You can use a program like recuva to see files but you would need to see the drive. To see the drive you may have to take it out of its outer layer and connect the drive to a sata cable within the computer. The computer may recognize it that way. Now if that seems to difficult i recommend taking it to a computer repair shop where they can pull the data off for you or contacting the manufacturer and maybe the product is still under warranty.
Oct 19, 2012 | Fantom Drives 120 GB Hard Drive
Hard drive clicks several times when turned on,
I have to say from the sounds you describe the Hard Drive is totally destroyed, the noises you can hear are the mechanical parts inside grinding and clanking together. If the information is critical it may be recovered by a specialist data recovery company, but we are talking £100's even £1000's to do the job, so otherwise I would suggest taking case apart and buying a new hard drive for it.
Sorry its not what you want to hear but it sounds very terminal to me.
The reason the PC can detect a device is that it can see the Interface card that sits between the USB port and the Hard Drive.
Mar 03, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
External hard drive isn't recognized!
try pluging it into a different usb port try a different cable if they all do not work then the partision table has been damaged and the drive will have to be reformatted
Dec 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB not recognized
Sometimes it helps to reinstall the drivers for the USB hub/controller in the Device Manager.
For other ideas, have a look at these external HDD troublshooting tips.
Hope it helps.
Jules
Jun 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Beeps and computer not reading USB port
usb drive get faulty. replace it.
Oct 03, 2008 | Computers & Internet
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
EXTERNAL HARD DRIVE BY SIMPLE TECH 500 GG
First, check the warranty status. They should give you a replacement. The following will probably void your warranty... This external drive probably houses a standard hard drive used in a desktop computer. If you don't mind voiding your warranty, you could disassemble the protective "shell" and check to see that the cabling to the drive is properly attached. I've seen a external drive which the interface cable was partially unattached. If all looks OK here, you could remove the actual hard drive and try hooking it up to a standard desktop computer. If you or a friend is reasonably tech savvy, such is a plus. It could be set as a secondary drive, and then you could see if files could be accessed. If nothing above works, then your outlook is bleak. There are businesses specializing in file recovery from a dead drive, but it is expensive.
Aug 08, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
Maxtor OneTouch 4 Mini 120GB External USB 2.0 Hard Drive Logo
149 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
