Question about Ricoh Aficio 2018 Copier
Smudges on copies - Ricoh Aficio 2018 Copier
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
First try to clean cleaning roller in fuser unit
Posted on Jan 01, 2011
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
Dirty copies on Canon PC1060
First replace drum cartridge
Nov 04, 2009 | Canon PC1061 Copier
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Smudges on copies
Check the fuser for physical damage
May 18, 2009 | HP LaserJet 4250n Printer
Canonimageclass D320 makes smudged copies. What do I do?
This model is noted for a jam in the fuser area around the roller, Not easy to get to but sounds a like that may be proble, Can you hear a sound like paper wrinking as it runs. Also is the drum in the cartridge clean or has tone on it. Have you changed the cartridge. I do get a kick out of Staples Experts.. They did sell you some cleaning sheets... Hey Good Luck....
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
Lexmark C522 color printer has black smudges on copies.
It's more than likely a scratch on the photoconductor unit. I had to replace one last week. If you have a spare, try to replace it to confirm.
Mar 13, 2009 | Lexmark C522n Laser Printer
Smudging when copy comes out
There are several reasons, all of which will require a technician.
Do you mean the toner will wipe of page (unfused)? This is the Fusing pressure roller.
Do you mean smudge marks that don't wipe off? This is most likely either a drum (photoconductor) problem, or the Upper fuser roller - could possibly be dirty optics as well. But like I say, only a technician can help you here.
Feb 25, 2009 | Canon NP 6050 Copier
Copies come out of machine with huge black smudges
If the smudges are consistent, (roughly the same size and approximately in the same location on the page) it's your drum. If not it's your fuser.
Oct 09, 2017 | Computers & Internet
PC-65 (Canon copier)
A smudge across the copy can be in many different areas.
Some ideas.
The drum cleaner may be the problem as you indicate.
It may be a piece of paper ripped of dragging across the surface of the paper causing the smudge.
Also the fuser roll coating may be very worn and causing that.
One thing to try that can show you if the defect is on the drum cartridge, is start to run a copy, After the paper feeds and this is timing, shut the machine off when you think the paper should be about half way through the copy cycle, then see if the copy defect is on the unfused page, If it is smeared before it reaches the fuser, it is in the cleaning section, if it is not smudged, then it is most likely the fuser rollers are needing replaced.
First look for a paper fragment in the path, step 2 is to shut the machine down in mid copy and see if the defect is there.
The fuser is the hot area of the machine in the exit area, If you can take a flash light and look in there and see if you observe wear or heavy toner buildup on a roller then obviously thats the problem.
Jan 02, 2008 | Canon C130F Black and White Copier
Ricoh Aficio 2018 Copier Logo
71 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
