Question about Dolphin Maytronics Advantage
SKU # DLHD UNIT IN POOL WILL NOT MOVE --SEEMS DEAD FUSE IS OK
    President:
  • Dolphin Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up. If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin.
If none of this helps your problem could be in the power supply, cable or motor unit. The motor unit is the most likely problem.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Dec 30, 2010
How come my aquabot turbo will not move or pump water?
Probably the drive belt came off the pulley or the belt broke. Similiar to a vaccuum
May 27, 2014 | Aquabot Turbo Robotic Pool Cleaner
Pump seems to start ok - 240 volts - shaft spins but not enough water pressure to move the polaris cleaner?
It sounds like you could have some debris stuck in the impeller on this pump. This is a common problem and anything that gets past the pool filter can end up stuck in this pump.
Sep 03, 2011 | Polaris Pb4 - 60 Booster Pump
Replaced the battery in the car but now unit seems dead although power to inline fuse is OK. KD G386/385 Has it got an internal fuse ?
It might be a good idea to check all of the fuses in the car. The radio requires two power sources in order to work properly.
Aug 22, 2011 | JVC KD-G340 Car CD/ MP3 Player
Intex Krystal Clear Saltwater System for 2 weeks and now unit is dead. No display at all, no function. Power is on and receptacle for house power is fine.
Possible blown interanl fuse... You are required to call Intex and submit for warranty repair if under 2 years and if you have receipt.. Otherwise, you can look up blogs on how to open unit and replace the internal fuse.. Good luck.. Here's the intex number... 1-800-234-6839
Aug 19, 2011 | Intex Automatic Salt Water System for ...
No Power, No LED's. Circuit breaker OK
There is an internal fuse, however to access it the unit must come out. The outer case will need to be removed. The following link will take you to GE's website where you can get installation instructions. The fuse is available at ther parts site, but you can get a new on for less than a dollar at radio Shack. Take the fuse with you.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JVM1665DNWW
Mar 05, 2010 | General Electric Microwave Oven
AO error code
I would have to agree with you concerning the control module.
Jul 31, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward pool cleaner wont move
Make sure the feet have springs in place, move freely, and rubber not too worn. If that all looks ok, then probably too much suction pressure. Use gauge that came with unit to verify proper suction.
May 30, 2009 | Hayward Navigator Pool Cleaner
I have a Bose Wave radio which seems to be dead, no sound, Displa
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 28, 2009 | Bose Wave Radio II
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Dolphin Maytronics  Advantage Logo
104 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
