Question about Dell Latitude D610 Notebook
I have a Dell Latitude D610. It acts like Windows XP is starting then goes to the blue screen with the massage "Stop: coooo218 {Registry File Failure} The registery cannot load the hive (file); \systemroot\system32\config\system or its log or alternate. It is corrupt, absent, or not writable. Can you help? Lawnrest from MO
    Genius:
  • 1,288 Answers
Could be a few things, lets start with the simplest solution first. I assume you tried getting into safe mode first?
Reboot computer to the Windows CD and when prompted, go for the 1st repair option (R for recovery)
when you get the Dos prompt (back screen with white lettering) type in checkdsk /r. This will check your disc to see if there are any problems with it.
Reboot computer to the hard drive, see if this has resolved the issue, if not, you are looking at a second stage repair.
Now insert and reboot the CD rom and let it go to the point where it looks for an existing windows installation (the point past the recovery console). Click to repair the installation and allow it to complete.. you MAY get asked for your windows COA number.
If you STILL have problems after this, there is a possibility that the hard drive is damaged, usually this will show up in checkdsk or when trying to install windows again. Sometimes, even the repair function is not enough to make windows good again, and you may have to do a total re-install
If you get windows running again, i recommed you download a copy of HDD tune and run this on the drive, any bad sectors or RSA errors and you would be advised to get your data off asap and replace the drive
Posted on Dec 29, 2010
    Guru:
  • 679 Answers
Follow this instructions http://support.microsoft.com/kb/822705 to repair the Operating system and retrieve your files. Or you can just reinstall the Operating system to make things easier if you dont have any important files in your computer.
  • Dell Master
  • 6,771 Answers
The windows software may be corrupted causing start up failure, but is more than likely the hard drive is bad. If you have the original recovery disc do a complete re-install of the operational system, if this fails then suspect a bad hard drive.
    Guru:
  • Dell Master
  • 2,178 Answers
Yes, the hard drive is corrupted. You will need to re-install the XP operating system or do a factory recovery. Check the Dell website for your computer through support and determine how.
My dell latitude D610 laptop keeps blue screening after selecitng the operating system (has 2 downloads of windows XP) and the stop code is "0x0000000A (0x00000002, 0x00000001, 0x804E7A0A)
Windows XP at this point is very buggy due to lack of support
Try to access your unit in safe mode and see if it works
when powering on press constantly F8 then select safe mode
if you are able to get in - try to save your information
if unable to get in and still getting a blue screen it could be either a system failure or hardware failure
Oct 17, 2014 | Dell Latitude D610 Notebook
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Dell latitude d610 upon boot, msg "The file nvrd32
You need to reinstall your operating system.
If you encounter this while installing XP, then you need to use another CD
Jul 17, 2011 | Dell Computers & Internet
When i power up my dell latitude d610 it starts on the safe mode screen. After the windows loading screen theres a quick blue screen flash and it goes back to the safe mode screen. And i t does this for...
There is a problem with the start up files of windows. Try going into the "Start-up Repair" option of the windows, either by inserting the Windows installation CD and then rebooting the notebook or by pressing F1, F8 or F11 (depends on the manufacturer).
Please take a look at the following link from the Dell's website for further details: http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_316068&isLegacy=true
Jun 25, 2011 | Dell Latitude D610 Notebook
I can not install the video drivers i need to my Dell Latitude D610 so i can play second life
Dell Latitude D610 Drivers (for Windows 2000, XP)
From the above link you can download the VGA (Video) Drivers. Double click the downloaded file and follow the on-screen instructions to install the drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Computers & Internet
MY LATITUDE D610 DOES NOT BOOT UP or RATHER IT GOES TO A BLUE SCREEN WITH AN ERROR CODE c0000218 . SINCE IT DOES NOT MOVE FROM THAT BLUE SCREEN I CANNOT DOWNLOAD THE SCAN AND REPAIR TOOLS U RECOMMEND...
Unknown Hard Error, if a corruption of the registry.
Run HDD diags and see if the drive fails, if it does, then the HDD is bad. You can try booting to you XP CD and running CHKDSK in recovery console.
Otherwise, reinstall windows
Sep 24, 2010 | Dell Inspiron 8600 Notebook
My dell latitude D610 does not hibernate. the option is there but it does not work.
fix ur os errors with reg in out registry cleaner and then do this Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files.
Sep 21, 2010 | Dell Latitude D610 Notebook
Dell D610 will not boot to hard disc
in os installed not corrected driver (s).
1. when goin bott press F8 and select "Dont reboot when error..."
windows go in blue screen, and write to screen what still by error (file name)
2. Try boot in safe mode. Find and delete this file.
3. Boot in normal mode.
If dont work. Boot with help WinPE bootdisk and scan your system by Viruses and Malware
Nov 07, 2009 | Dell Latitude D610 Notebook
Start up problem, after on button, dell load screend 0
welcome to fixya
I would just try to restore with the restore disks
sounds like your hd has a few bad sectors on it
if your using vista it will ask you if you wish to repair windows i would try this ..if not using vista then try restore windows
i hpe this helps you out have a great day :)
Jul 18, 2008 | Dell Latitude D610 Notebook
Dell Latitude D610 Notebook Logo
404 people viewed this question
Alun Cox
