Question about Canon PowerShot A400 Digital Camera
New batteries only give me one or two stots and then the camera says change the batteries. Could this be a camera fault. I can't go on returningf batteries to the store. Please help
    Scholar:
  • 66 Answers
Hi
The Canon PowerShot A400 is quite an old camera now and whilst it may not be the camera it could be another part of the kit.
If you are using rechargeable AA batteries, which should give the best performance, it could be the battery charger has lost it's ability to charge the batteries.
If you are using standard AA Alkaline batteries, check the battery terminals in the camera, as it could be they are dirty and need to be cleaned.
Hope this helps
David
Posted on Dec 29, 2010
My camera does not reconize new batteries i put the batteries in and it says low battery and shuts off
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Fuji FinePix A500 Digital Camera
I have a Polaroid i733...I just grabbed my camera to take a picture and it turned on for a second and then went off. I tried pushing a/any button but nothing happened. I changed the batteries out, the same...
Hello
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Polaroid i733LP Digital Camera
Coolpix 3200. when i turn camera on, the lense
Hello
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Nikon Coolpix 3200 Digital Camera
Casio Exilim EX-S600 Digital Camera will not turn on... i changed the battery... and nothing happens
Hello
Anything is fixable but it is more "is it cost effective"
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Casio Exilim EX-S600 Digital Camera
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
Not coming on with new batteries (have tried several new batteries)
this problem seems to be caused by a faulty battery protection switch fault, which is situated in the battery compartment.
May 28, 2009 | Olympus FE-110 Digital Camera
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
Insufficient power to start, even with new batteries?
My Dad (in-law) has one of these cameras and has tried several re-chargeable batteries.
Some of the less powerfull ones wouldn't even start the camera, others just didn't last.
He has now resolved to only using Duracell, as they are the only ones which give enough power and he always carries spares.
hope the helps !
OBC
Sep 09, 2008 | Canon PowerShot S2 IS Digital Camera
JVC GR-DX67EK Remove and replace battery fault
Hi again,
Appreciate the "Ask Me". With your indulgence, I would be reposting this in your original problem/post here.
Bear with me on this one, the battery. Your post, "wind the tape for much longer" (all other things being equal) would indicate a comparatively weak power source (the battery). Assuming that the battery is not weak, then the problem may lie on how the power of the battery is transferred to the camera.
Here is a test, try the camera with the AC adapter (with or without the battery). If problem persists, then it is internal to the camera, if it works and you could perform the reset, then it is a battery issue.
As earlier stated battery issues need not be the battery itself, it maybe how the battery transfers power to the camera. Check the terminals of the camera where the battery contacts. Clean or scrape and when you try the battery, apply manual pressure (press on the battery) to add force to the contact. See if problem persist.
Software (firmware) update - I am not aware of any updates for your particular model GR-DX67EK, however pls try here.
Again, good luck and would appreciate an update at your convenience.
Jul 25, 2008 | Video Cameras
Batteries
Suggest this a camera fault- return to seller or contact the Samsung web site Tech support Team
Jun 25, 2007 | Samsung Digimax S700 Digital Camera
Canon PowerShot A400 Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
