Question about Brother CS-6000
Machine does not recognize zipper foot or different stitches
    Genius:
  • 1,788 Answers
I am not sure what you mean by the machine not recognizing the zipper foot. Do you mean that your machine will not do the different stitches? I have this same machine, and I will be glad to check mine and compare with you anything that you want to know. I am answering you for free, so if you find a better answer, feel free to accept it.
Posted on Dec 29, 2010
Testimonial: "Thank you Wiz for responding"
  • hiiting40 Apr 05, 2011
    To "mrhobbs" - I know what you mean by the zipper foot not being recognized, as I am having the same issue.
    Unlike the other feet (J,R, A & N) that appear on the lcd screen so one can select depending on the foot in use, when attaching zipper foot "I" -which comes with the CS-6000i when purcahsed- this foot type does not appear to be programmed into the machine, and thus cannot be selected. I tried selecting J (using foot I) with the 01 straight stitch, but the stitchs are coming out wrong.
    Any help out there?
Why can't I reverse stitch properly on Bernina 1008 when using zipper foot?
please check that the foot is attached on the drop arm in the correct position as it sounds like the foot is not down far enough to reach the base plate I have had the same problem when you have more than one foot in your spares box eric
Dec 12, 2017 | Bernina Sewing Machines
I need a zipper foot for my Pfaff 1047. Where cn I find one?
Pfaff - Zipper Foot for IDT™ System (1)
www.pfaff.com/en-GB/Accessories/Zipper-Foot-for-IDT-System
The Zipper Foot is the most important zipper tool and will help you stitch the zipper perfectly in place. When attaching any zipper, it is important to sew right next ...
Pfaff - Invisible Zipper Foot
www.pfaff.com/Accessories/Invisible-Zipper-Foot Invisible zippers are the least noticeable of all zippers. As the name implies, the zipper is hidden in a seam, becoming virtually invisible. This makes it a popular ...
Pfaff 1047 Sewing Machine Parts - Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts Rating: 4.8 - ‎91,711 votes
Results 16 - 30 of 77 - An Online Pfaff Parts Superstore, We also supply 1047 manuals, presser feet and accessories. Fast, free shipping over $75. zipper foot for my Pfaff 1047 Google Search
Feb 27, 2017 | PfaFF Sewing Machines
What type of foot do I need when attaching popper closure tape to a duvet cover.It needs to leave more space under foot for popper height.
You do NOT want to sew over the popper. Instead, use a narrow zipper foot and adjust your machine needle to stitch just on the very edge of the tape. Hitting a popper will definitely break your needle and possibly knock the machine out of time.
Be sure to get the right foot to fit your machine!
Your machine's zipper foot may not look like this, but it should give you the basic idea.
How to Use Zipper Foot Sewing Parts Online Everything Sewing Delivered...
Zipper Foot Adjustable Low Shank 55411
Oct 23, 2016 | Sewing Machines
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
Oct 01, 2016 | PfaFF Sewing Machines
How can I attach a zipper foot to my unidentified machine?
Assuming you have the correct zipper foot attachment for your machine, you should be able to attach it like any other presser foot. On some machines, you may need to adjust the needle position to the right or left so the needle will not hit the presser foot when stitching.
Feb 10, 2016 | Sewing Machines
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
As soon as I put on a zipper foot the tension on my ddl 5550 loosens. when I put on the regularfoot its fine. anyone else having this issue?
The 'shank' on your zipper foot is too long and is holding your upper tension open. When I get a rogue foot like this, I set my old foot and my new foot, side by side on a flat surface and measure the height from the surface to the bottom of the hole where the foot is screwed onto the presser bar. When I see how much difference there is, I mark it and take my Dremel and cut the hole lower on the new foot. This will usually fix the problem. The only other thing you can do is to adjust the height of your presser bar to accommodate the zipper foot but now it won't fit your regular foot so you have a new problem. :)
Aug 01, 2015 | Juki DDL-5550 Industrial Straight Stitch...
Stitch issues with zipper foot
Fist off, Do you mean then, that the top looks bad. If it's the bottom that looks like train tracks, it's actually the top tension. My fist suggestion is to rethread the top and make sure it catches the take up lever and the tension disc.....Otherwise, you may actually need to loosen your top tension....
Sewing Machine Tech
Oct 24, 2013 | Singer 4423 Sewing Machine
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
Brother CS-6000 Logo
57 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
