How do i wire 2 zone value 4 wire 2 red 2 yellow to a aquastat
    Sergeant:
  • 182 Answers
Need to know the name of the zone valves, then I can help you. also name and model of the aquastat.
Posted on Dec 29, 2010
Powers on then off with 4 red binks then 2 amber?
A blinking red and yellow Status LED will indicate an Error Code that can help determine the cause of a circuit
failure.
• The number of Red blinks indicates the value of the (tens digit) of the Error Code.
• The number of Yellow blinks indicates the value of the (ones digit) of the Error Code.
Example: If the Error Code is "37", the LED will continuously blink Red three times, followed by blinking Yellow
seven times.
25846923-00ymvd0zfh3oypxbgkhcneuw-4-0.jpg See the following for a list of Error Codes.
To perform a System Reset, press and hold the Power button for 10 seconds. Or, unplug the set for 10 seconds
then restore power.
http://electro-medical.blogspot.com/
Sep 02, 2015 | Mitsubishi WD-73638 3D-Ready DLP HDTV
I have installed honeywell aquastat relay per instruction manual on my dunkirk xeb-4 lp boiler furance with honeywwell ignition unit s8610u but it wont ever start the exhaust fan checked everything several...
If aquastat wirings are ok, and control module had been set up properly, the the furnace should start.
Check if bypassing the control the furnace starts, if it starts then check aquastat wirings.
If it depends on the furnace, check the valve, the safety sensor and the ignitor.
Here is the guide to set up the Aquastat control:
Guide to Setting & Wiring Heating System Boiler Aquastat Controls
Sep 13, 2008 | Honeywell Heating & Cooling
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
How do i install a zone valve in my hot water heater. I need the schematic from boiler controller to the valve. if I tie the first floor to one valve , the rooms (2) will be on the last section before the...
The two zones have seperate supply and returns, correct? If not zoning will not be possible without piping the system in that way. Assuming the piping is correct, for two zones, you will need two zone valves, one cut into each zone. The wiring will vary, but for a 3 wire zone valve, (Taco), power from the transfomer goes through the thermostat, into terminal 1 on the Zone Valve, Terminal 2 on the zone valve goes back to the transformer, (24v common), and also to one "T" terminal on the aquastat (boiler control), and Terminal 3 on the zone valve goes to the other "T" terminal on the aquastat.
For a Honeywell, or other motorized Zone Valve, power again goes from the transformer, through the thermostat and into one side of the motor contacts/wires (depending on brand), the other motor wire goes back to the transformer, (24v common) Then the two end switch contact/wires go back to the T T terminals on the aquastat.
If you are using motorized zone valves, and only 2 of them, the transformer in the aquastat will be strong enough to power them.
Hope this helps
Jul 04, 2009 | Kenmore 75944 Gas Dryer
Hello sir, the system zone-2 temp., always keeps flashing in red.
It is a motherboard problem. But you can disable that alarm from the BIOS. I would simply raise the upper threshold in zone two from 56 to 60 if I were you. If it still flashes red put it back to 56 and disable it.
Apr 26, 2009 | Intel D865GBF Motherboard
Boiler will not shut off
boiler does not shut off when thermostat reaches temp, i already replaced aquastat but condition still exists
Nov 14, 2007 | Heating & Cooling
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
