Question about Toshiba Televison & Video
Tengo un problema de vertical en una television toshiba modelo 27A45 en algunos canales se posiciona bien la pantalla pero en otros no, se ve la parte superior de la imagen en la parte inferior de la pantalla una ralla gruesa y en la parte superior de la pantalla se ve la parte inferior de la imagen la television utiliza el c.i. LA78041 ya cambie todos los capacitores electroliticos del vertical pero continua la falla espero alguien me ayude a resolver el problema gracias.
  • 247 Answers
SOURCE: recuadro negro en el centro de la pantalla modelo 55fx20b hitachi
in english please
Posted on Jan 11, 2009
rulds2008
  • 3866 Answers
SOURCE: un canal de mi televisor
Esto es un codico que ustedes poner en de V-chip, Y no hay como combiar, Que es de modelo de esta tele? Que es de numero de modelo y de fabrica voy a buscar un forma aver se hay or no.
Gracias
Posted on Aug 03, 2010
Testimonial: "es muy sabio ¡¡"
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
SOURCE: tengo un plasma sanyo 50
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Posted on Feb 23, 2011
polos_leds
SOURCE: tengo una ricoh aficio 1232c
how do i get the option 2109 working with a ricoh 1224c, i don't 2109, please help
Posted on May 14, 2012
Mi tv mitsubishi presenta falla al momento de ver una entrada ya sea digital ..hdmi o rca se miran rayas purpuras de lado a lado alguien me puede ayudar
Tengo un Mitsubishi 73 inch el prende pero no se ve nada en la pantalla pero se oye despues de 5 minuto prende la bombilla roja y no se ve nada ni se oye
Mar 18, 2014 | Mitsubishi WD-62525 62" Rear Projection...
Tip
Telstar CB2194F Rayas horizontales
Este TV usa una tarjeta generica la he visto tambien el algun modelo Sanyo<br />Al encenderlo presentaba una pantalla negra con unas rayas horizontales de colores<br />en la parte de arriva de la pantalla.<br />luego al agarrar brillo la imagen se presenta bien com buenos colores<br />pero con unas rayas finas horizontales en la parte superior.<br />Manteniendoce todo el tiempo.<br /><br />Despues de reemplazar algunos capacitores, el problema se resolvio reemplazando el<br />Capacitor C406 del vertical STV9302A
on Aug 05, 2011 | Televison & Video
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Sep 12, 2010 | Televison & Video
Imac g5 linea blanca vertical en la parte derecha
éstos son algunos procedimientos que se pueden tratar de resolver este problema con la línea blanca de la pantalla. Pero, por favor tenga en cuenta: si estos 2 procedimientos no ayudan, te recomendaría tener en tu Mac en el servicio de Apple en un centro de servicio autorizado
éstos son algunos pasos que usted puede tratar de resolver el problema:
Opción # 1
-PRAM reset -
• En primer lugar, sostiene en su botón de encendido durante aproximadamente 10 segundos para hacer una parada difícil, si no se ha cumplido ya su Mac apagado.
• Una vez que tu Mac está apagado, usted tendrá que realizar lo que se denomina un restablecimiento PRAM (RAM de parámetros)
• Busque las siguientes teclas en el teclado: Comando, Opción, P y R. Es necesario mantener estos teclas simultáneamente.
• Encienda el ordenador.
• Mantenga pulsado el Comando + Opción + P-R llaves. Debe pulsar esta combinación de teclas antes de la pantalla gris.
• Ahora, presionando las teclas hasta que el equipo se reinicia y se oye el sonido de inicio por tercera vez.
• Suelta las teclas y permitir que el MacBook a poner en marcha.
Opción # 2
-Restablecer la PMU -
El administrador de energía es un circuito integrado (chip de ordenador) que suele ser en la placa lógica de su ordenador Mac.
Es responsable de la gestión de energía de la computadora. Controla la retroiluminación, giro del disco duro, el sueño y la activación, algunos aspectos de la carga, control de trackpad y algunas entradas y salidas en relación con el reposo del ordenador.
• Si el ordenador está encendido, apágalo.
• Desconecte todas las conexiones de entrar en el Mac, excepto para el cable de alimentación.
• Una vez que todas las conexiones se han desconectado, quite el cable de alimentación de la Mac.
• Espere 20 segundos.
• Vuelva a conectar el teclado, el ratón y el cable de alimentación en el equipo.
• Presione el botón de encendido para reiniciar el equipo Mac.
Espero que esto haya ayudado a resolver el problema de la línea blanca.
Recuerdos,
-Mactechtrainer
Jan 29, 2010 | Apple iMac G4 Desktop
Tengo un tv que tiene la falla en la convergencia de colores
Hola, gracias por visitatar fix ya.
Mira, tienes un fusible abierto, que no te permite entrar a los ajustes.
A un lado del fly back hay tres pastillitas colo cafe ( fusibles), el de enmedio es el que tienes que cambiar (400ma), pero tienes que resoldar toda el area del fly back, por que ahi tienes falsos o loose connections.
Si tienes alguna pregunta, aqui estare.
Gracias.
Jul 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problema tarjeta sabrent
Hola, que tal yo tengo un problema también con la TV Tuner de Sabrent, pero en mi lap tiene Windows Vista y no me detecta audio.
¿Cómo le hiciste tu para que detectara audio al sintonizar la TV y capturar video?
roy_villafuente2510@hotmail.com
Dec 02, 2008 | Sabrent TV Tuner / Video Capture Box USB...
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
