Question about Pentair Whisperflo 1 12 Hp Pool Pump Wf26 011773 ()
I just had someone look at my WF-6 pump because of a loud whining sound. Everything is running fine, but noisy. They said they believe the bearings are going out and suggested replacing the entire unit for around a grand. How difficult is it to have the bearings replaced? Do you have to send the motor off, or is it something that can be done at home? It just doesn't make sense to replace everything when all is fine except the bearings... Any suggestions would be appreciated. Thanks
    Problem Solver:
  • 16 Answers
You can have the bearings replaced for about $100. It is something that you will have done by a professional. Consult with a local pool store and they should be able to direct you to someone that does that.
Posted on Dec 29, 2010
98 cadillac deville noisy ps. pump , fluid does not circulate
Sounds like the bearing on the pulley that runs the Power Steering pump is shot. Have it serviced.
Aug 06, 2012 | Cars & Trucks
Start pool up this year pump is louder makng whine noise, works fine and it is not getting hot Is the pump going
loud screaching noise??? sounds like bearing failure. this most common failure of pool motors. YOu can try to replace the bearings or replace the motor.
May 22, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Our mr slim has recently became very noisy. The motor whines very loudly when running. It sounds like a jet engine startring.
3 things come to mind:
1. something stuck in the blower section
2. motor bearings are failing
3. blower wheel welded connections have loosened
Mar 12, 2010 | Heating & Cooling
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Noisy long high pitch whining fan
Try changing the toner cartridge. I have seen this problem before.
Jun 15, 2007 | Samsung CLX 3160fn All-In-One Printer
Loud Whining/Humming noise while washing
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Feb 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Pentair Whisperflo 1 12 Hp Pool Pump Wf26 011773 () Logo
131 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
