Question about Danby DDR2504 Dehumidifier
Danby DDR503H operation
I havce been trying to operate the dehumidifyer that was left in a home when we purchased it .. seems like when I turn it on to get the humidity out of the house all I feel from the fans is heat can you please tell me how to properly operate this as I do not have a owners manual
Just go there and download the user manuel in pdf for free.
http://www.retrevo.com/support/Danby-DDR503H-manual/id/886ci677/t/2/
Posted on Aug 05, 2008
Online manual.com
Home Hardware might be able to supply a manual although could be a Honeywell underneath.
Jun 09, 2014 | Danby Dehumidifiers
Need manual for danby Model # DDR557HE Seial # 0107040706556
Here is a link to a generic Danby user's manual which should help out since they all use the same basic controls:
http://www.danby.com/cms/uploads/products/en_manual/DDR5009,_6009,_7009REE_EFOM.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 28, 2011 | Danby DDR557 Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Danby Dehumidifier
Danby DDR6009RRE dehumidifier bucket switch operation question.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 27, 2010 | Danby DDR6009REE Dehumidifier
I have DDR5588RHE with the same problem
I had that problem several years ago when I lived in a more humid area. I figured out what was causing it to shut off, and adjusted the shutoff switch by increasing or lessening the force of a bi-metal actuator that was operating the switch. My memory is very dim as that was sometime back, and those details I gave may not be exactly correct. I am guessing that it was that type of switch and it was operated by temperature....and was shutting off the compressor when the heat was really not that bad. It could be that if it means the difference in getting some use out of it or just throwing it away, you might decide to just remove the switch from the circuit (bridge it with a piece of wire).
Aug 20, 2009 | Danby DDR401 Dehumidifier
Need operating manual for Simplicity phd, model# SHCC6026. thnks.
where do i hook up a hose to drain water to sump pit on my simplicity dehumidifier?
Jun 10, 2009 | Danby DDR601 Dehumidifier
DeLonghi DH250R dehumidifyer - operating instructions?
http://www.delonghi.com.au/support/instruction_manuals/DH250R.pdf
Apr 05, 2009 | DeLonghi Dehumidifiers
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
Problems with Danby SHCC6026 Simplicity
It's normal, the motor is running while it's not powered on to make the water filtered in the tank.
Do you get problem with water get on the floor?
Apr 07, 2007 | Danby 60-Pint Dehumidifier
Danby DDR2504 Dehumidifier Logo
1,155 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
