Question about Brother IntelliFAX 4100 Laser Fax
Needs to order a new drum - Brother IntelliFAX 4100 Laser Fax
  • 6,771 Answers
Go to www.brother.com and look up customer support to see they can provide you with the item, or a store close to your location that will meet the need.
Posted on Dec 29, 2010
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
When i print more than one pages. the 2nd page and later will always have shadow from previous page printout.
Drum Unit is not cleaning.
Either is not producing the right charge in the corona wires
your wiper blade is not functioning or the roller speed/ fuser speed is not correct
easiest solution clean drum with dry cloth
order maintence kit and replace rollers
next order new drum unit
order new fuser
Oct 28, 2013 | Samsung CLP 315 Laser Printer
Replacing the drum
Did you replace the drum unit? If not order a new drum unit & install the drum and read the paper work with the new unit. There is most likely a life counter that needs to be reset. Good Luck
Oct 03, 2012 | Dell B1160
I took my washer all appart to clean the gum out of the tub now the spin cycle hits and bangs the sides so much you cant use it
Assume this is front loading washing machine, Check drum dampeners are firm, any cables that were held by cable ties near the drum and were removed in order to remove the cables in order to access the drum need to be replaced with new cable ties, there shouldn't be anything loose dangling around near the drum, as it will strike when the drum vibrates during its spin cycle.
Jan 15, 2011 | Kenmore Washing Machines
Drum light flashes
This means that you will need to replace the drum soon. Order a new drum and when the light becomes steady or the print quality becomes poor, replace the drum. The drum should last ~12,000 pages. The part number is DR350. You may be able to order this from your Office Supply store; otherwise try the Brother Mall site: http://www.brothermall.com/Accessories/AccessoryDetail.aspx?AccessID=DR350&AspxAutoDetectCookieSupport=1 .
The procedure is similar to replacing the toner but instead of putting a new thing of toner inside the drum, you remove the toner and put it in the new drum. Open the front cover and pull out the drum and toner assembly. Place on newspaper or other disposable material (toner may spill). Push down the blue lever to unlock the toner cartridge. Remove the cartridge from the drum. Unpack the new drum (keep it out of the light until ready to replace the drum). Push the toner cartridge into the new drum until it locks into place; the blue lever should lift automatically. Put the assembly back in the printer. Clean the printer as recommended in the manual while it is open; this includes cleaning the corona wire before replacing the drum assembly.
After replacing the drum, reset the drum counter: with the printer on and the drum light blinking, open the front cover and press and hold the GO button until all of the LEDs light up (about 4 seconds). Then release the GO button and close the cover. Check that the drum light is off. (The manual says you should do the reset first but I tend to avoid this in case of distractions.)
I hope this helps.
Oct 06, 2010 | Brother HL-2040 Laser Printer
Noise in drum sound like its gonna blow up
hello, unfortunately the wf321 drum does not split the bearings and drum come as one complete unit and so you need to order a drum unit complete with new bearings and replace the lot
Jun 02, 2010 | Hotpoint Washing Machines
What is the part on the inside of dryer door with the seal around it called and can you order it
Im not exactly sure which part you are talking about, but if your referring to the actual container that holds the clothes its called the drum. If your talking about the small plastic pieces that stick into the inside of the drum those are called fins. If you need new fins, you cannot order them separately you will need to replace the whole drum. So in either case your getting a new drum. Most appliance part stores don't carry such a large item in stock but you may get lucky and the store can usually order one as long as you give them the model number of the machine.
Dec 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Drum light stay on but it will not let me print?
In most cases, if you are going to replace it yourself, when you order the new drum it should come with instructions on how to replace the old drum with the new one you ordered.
Usually this is done by a professional printer repair person, due to the possibility of there being complex changes to make while changing the drum.
Jun 20, 2009 | Brother HL-2040 Laser Printer
Brother IntelliFAX 4100 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
