Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Kenmore manual upright freezer
The freezer is defrosting but it is plugged in...i know i need to defrost it it is full of ice could this be the problem. at first the red light didnt look on so i pressed the button andand it looks brighter...my husband was sweeping yesterday could he have knocked it...
We got alot of ice chest and cleaned out the ice. this fixed the problem so far. we dint lose any food thank goodness.
Posted on Jul 08, 2008
My kenmore freezer stopped working for about two days it had been leaking water for a few months, then it started working again?
It could be that your defrost system is faulty. If the freezer does not defrost now and then it will fill up the cooling fins with ice and get warm. The leaking could also be an indication of two much ice. Did you unplug it when it stopped working and then plug it back in?
Sep 21, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Groaning Kenmore 13.5 cu. ft. Upright Freezer
This sounds like you either have a bad fan motor or if you have ice built up on the inside back panel. It could be that the fan blades are hitting ice built up around it. If so, you will have a defrost problem that will need to be addressed to fix the unit. But to repair it so it will stop making the noise, you can defrost the ice (if present) with a hair blow dryer. This will keep the ice away for a few days. Good luck.
If there is a defrost problem, the heater (located around the coil) is most likely the problem.
Nov 17, 2009 | Kenmore Freezers
Freezer is on and just stopped working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Aug 15, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Upright freezer starting to defrost
remove the back panel of the freezer and see if the evaporator is a block of ice (evaporator is something kind of like a radiator) if is a block of ice replace the defrost thermostat ( a little sensor whit tow wires)
and the defrost timer ( usually next to the refrigerator thermostat inside the fridge side)
you can find this parts at your local appliance part store or online here is a link good luck
Jul 22, 2009 | Kenmore Freezers
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
131 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
