Helo - Computers & Internet
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Rc helicopter not getting signal from remote
I think you have damaged the copters electronics when you crashed it.
Jun 27, 2017 | Toys
My nokia6300 no network problem what pfo jumper solution plz
Try below steps
- Check network wiring path (connectivity to the antenna) - Re-Hot PA - Re-Hot RF area
Try do as per attached picture shown below
Mar 07, 2011 | Nokia 6300 Cell Phone
Helo, i want to play desperados 2 cooper's revenge on my pc with windows 7. but is does not work?
helo,i want to play desperados 2 cooper\'s revenge on my pc with windows 7. but is does not work and some error like that m_hdc and m_hglrc please solvem it ok buy
Dec 20, 2010 | Atari Desperados 2: Cooper's Revenge for...
I bought my sons Walker Lama 2 Copters and we need
Is the lower shaft blade not rotating.. and making flimsy noise....and olnly the upper rotor blades rotate and it does not fly even at full throttle...
If above is the problem, then check the corresponding motor gear, if you could see, white shades over the black, plastic body, then the chances of that gear, might have been worn out.. if it is the same, then replace the gear, it should work......
Mar 20, 2009 | Walkera HM5#10 RC Helicopter
Spark plug required repair by helo-coil
Helo-Coils Rarely Stand up Long For The HEAT of Combustion Chamber Not trustworthy at all the way it is
Feb 21, 2009 | 2000 Subaru Impreza
Nokia 1100 security code locked
helo sir
(3201173501) to unlock the security code but all these are not working i also tryed 12345 not working
please help me out and also tell me how to use these codes on phone
thankzzzzzzz ......... ..........
Jul 30, 2008 | Nokia 1100
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
