Question about Kenwood DNX7140 Car GPS Receiver
Dc offset error code - Kenwood DNX7140 Car GPS Receiver
My screen on my kenwood dnx 6990hd says (DC OFFSET ERROR) What does thay mean
Basically that means there is an overload or some form of power issue with the machine.
The best thing to do is reset the unit to start with. Do you have the manual?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 28, 2016 | Kenwood Knob Dnx-6980 Dnx-6180 Dnx-6190hd...
Hi! i am trying to detect a problem in my sony model HCD-GZR777DA when switch it on, after waiting it display c 31 00. where to start please help
31: DPD offset adjustment error .
Contact any service technician. You can't repair this. The error code list to this set:
The meaning of error code is as below:
01: Communication error (No reply from syscon)
02: Syscon hung up
03: Power OFF request when syscon hung up
19: Thermal shutdown
24: MoveSledHome error
25: Mechanical move error (5 Changer)
26: Mechanical move stack error
30: DC motor adjustment error
32: TE balance adjustment error
33: TE sensor adjustment error
34: TE loop gain adjustment error
35: FE loop gain adjustment error
36: Bad jitter after adjustment
40: Focus NG
42: Focus layer jump NG
51: Spindle stop error
52: Open kick spindle error
60: Focus on error
61: Seek fail error
62: Read Q data/ID error
70: Lead in data read fail
71: TOC read time out (CD)
80: Can't buffering
81: Unknown media type
Are you confident to do anything with these error displays.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Sony Audio Players & Recorders
Miswiring dc offset error comes on my radio and it wont play
That means a speaker is shorted or the wire for the speaker has come in contact with the chassis of the vehicle.
Feb 26, 2016 | Car Audio & Video
Kenwood with dc offset
DC offset is most often caused by the bias level for the output transistors changing for some reason. This could just be that the control is dirty and needs to be cleaned and re-adjusted, or the biasing network has a problem, most likely the diode or transistor that is being used to set the reference. The diode or transistor is often mounted to the heatsink for thermal feedback, which allows the bias to change depending on how hot the output transistors are getting, There is no mention as to how high the DC offset is. The usual range for DC offset adjustment is less than +/- 1 volt. If your offset is higher than this, there usually is a problem with the bias circuit that needs to be repaired. If it is MUCH higher, then one of you output transistors or driver transistors is most likely defective.
Jun 16, 2014 | Audio Players & Recorders
Error u60
code u60: Job offset home position sensor does not detect home position for the Job Offset Assembly.
check
home possition sensor actuator
home posiition sensor
sns harness ... is there any damage or misalignment. replace broken parts.
if that did not help
Test the job offset home position sensor.
run the service diagnostics offset home position test.
Does the sensor function correctly?
If yes you well have to replace the engine control board. That will give you that error. Hope this helps if you need more help let us know at iteminconline.
iteminconline
Nov 04, 2013 | Xerox Phaser 7400/DXF Laser Printer
Miswiring dc offset
Saying miswiring dc offset error i unplug batt radio works for a sec till i turn up then comes back on
Jul 12, 2013 | Kenwood Ddx719 Dvd Cd Mp3 Ipod Iphone...
DC Offsets on output - protection don't allowd to switch on
you don't want to do this( bypass the protection0
that d.c. output will burn the coils in your speakers with out making a sound!! you have a biasing problem
or like you said a d.c. offset problem it is best to work on this problem with out a load on the amp, this will allow you to trace back where the trouble is starting at. caps will cause this sort of problem but leaky transistors can also do this, even diodes.
this will require an experienced trouble-shooter.
Apr 26, 2010 | Audio Players & Recorders
What does the offset light mean on sony xplod amp
THIS IS "DC OFFSET". MOST AMPLIFIER PROTECTION CIRCUITS REACT TO THIS CONDITION BY SHUTTING THE AMPLIFIER DOWN. THIS IS A CONDITION, NORMALLY BROUGHT ON BY SHORTED OUTPUT TRANSISTORS, THAT ARE TRYING TO PASS THE POWER SUPPLY DC CURRENT TO THE SPEAKERS, WHICH IN A MATTER OF SECONDS, WOULD BURN THE VOICE-COILS IN THE SPEAKERS. MOST TIMES THIS WOULD BE CHARACTERIZED AS HOOKING THE SPEAKERS UP AND OBSERVING THEM SIMPLY POKING OUT OR IN CONSTANTLY WHICH CREATES MUCH EXCESS HEAT. THIS IS WHY THE AMPLIFIER WILL SHUT DOWN TO PROTECT THE SPEAKERS. YOU CAN TRY TO DISCONNECT THE SPEAKERS AND THE RCA INPUTS THEN POWER THE AMPLIFIER UP. IF THE DC OFFSET LIGHT STILL ILLUMINATES, THEN YOU WILL HAVE TO HAVE THIS UNIT REPAIRED. ONCE REPAIRED, BEFORE REINSTALLING IT, MAKE SURE TO CHECK YOUR SPEAKERS FOR DAMAGED VOICE-COILS, WHICH COULD HAVE BEEN THE PRIMARY CAUSE OF FAILURE. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Jan 10, 2010 | Sony Car Audio & Video
Xerox Phaser 7400 displaying error code u60. Even after rebooting.
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
Dec 17, 2009 | Xerox Phaser 7400/N Printer
What are errors 1to5 and 7to8
1- face down sd ram failure
2 face up dram failure
3 cpu dram failure
Sep 23, 2009 | Kodak i30 Path-Through Scanner
Kenwood DNX7140 Car GPS Receiver Logo
334 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
