Question about Juki Sewing Machines
I am having a problem with the automatic thread cut on the DDL-8500. It will sometimes cut the end of the needle off when used. It does not happen everytime. Sometimes the cutter will jam behind the needle when it is in the lowest position and bend the needle.
    Scholar:
  • Juki Expert
  • 176 Answers
HI THERE
FIRST OF ALL IS THERE ANY ERROR APEAR ON CONTROL? I THINK E007 HAPPEND.
1- TRY TO CHECK STOP POSITION FOR MACHINE IS IT CORRECT OR NO.
2- CHECK CAM FOR THREAD TRIMMER IS IT CORRECT OR NO.
3- CHECK THE PART NAMED THREAD GUIDE FOR KNIF MAYBE BROKEN OR MISSING.
BEFORE YOU CHECK THIS TWO REASONE TRY TO CLEAN ALL EARIA ARROUND FIXED KNIF AND MOVABL KNIF.
Adjusting the timing of the thread trimmer cam
How to adjust the timing
The timing of the thread trimmer cam for cot ton and synt hetic threads can be obulned simply by aligning the marker dot on the machine ann and the marker dot on the handwheel.
Till the machine head. manually tum the handwheel un til the thread take-up lever almost reaches its highest
position . and press th read take-up picket to the right by finger. This causes the earn toller 10 fit
in the groove of the thread trimmer cam. With this condition maintained, tum the handwheel in the direction
opposite to the nonnal rot ational direction . and you will find a position in which the handwheel no longer
turns. Then, adjust the cam timing so that marker dot on the machine ann is aligned with
marker do t on handwheel This provides the proper cam liming for ca tion
and synthetic threads.
Posted on Dec 29, 2010
I have juki ddl 8500 7 and the thread cutter will not worked
Is it making a noise when you try to cut? Most common is that your needle plate is bent down and is preventing your knives from doing their job. In this case, you can take the plate off, turn it over on a flat surface and use a hammer to flatten it. While the plate is off, test your machine and see if the blades are now moving. Make sure to keep your fingers away while you are doing this. :)
Now check to make sure your feed dogs are not cracked or broken and keeping the blades from moving. Next: Sometimes you either get a ball of thread or a piece of a broken needle caught in the blades as they try to cut and it can either bend the stationary knife (this knife is in the general shape of a backwards letter L) or break it off. If all the knife pieces are there, the small moving knife (that looks like a little flat fat bird with a big eye :) ) becomes dull and won't cut the thread when it moves against the stationary knife. In either case, you can replace the knife. The most common is to replace the stationary knife. It is the easiest to replace and can be ordered online with the part # from your parts book. If you don't have a parts book, try to contact your online sewing parts company for the part.
Mar 20, 2016 | Juki Sewing Machines
I have juki ddl 8500 and the needle will not pick up the bobbin thread.
Is this a new machine or have you had the problem before
Aug 13, 2013 | Juki DDL-8300
Juki DDL-8500 skips stitch
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Jan 02, 2013 | Sewing Machines
How solve Juki DDL 8700 automatic single needle machine E-7 error?
hi there,
1- check V belt if there's more loose plase make it tight littel.
2- check timming cam for thread trimmer , sometimes lock after trim and E7 appear.
please advice me type for control box ? i can give more help if you have basic knowledge for electronc. just email me if you want any time.
best regards
ashraf abozid
aabozid@hotmail.com
CAIRO - EGYPT
Jul 28, 2011 | Juki DDL-8700
The thread on my Juki machine keeps breaking when I sew. How do i fix it. Also, How can i change the thread tension
there's a tension dial with numbers-0-9 --above the needle area- the smaller the number the looser the tension--the higher the number the tighter the tension
thread breaking-try this
try rethreading the machine
thread tension to tight
needle is bent or blunt
needle is inserted incorrectly
the thread is either too heavy or too fine for the needle
try this & see if it helps you
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 26, 2010 | Juki DDL-8300
My juki machine ddl-8500-7 is locked how can I unlock it
hi there
can u check one by one
1 - loose screw for needle bar clamp and turn the wheel by hand.
2 - from down remove the finger for hook and turn machine pully maybe some thread insaid the finger.
3- loose the four screws for upper main shaft and turn the machine pully by hand.
best regards
ashraf abozid
aaozid@hotmail.com
Aug 13, 2010 | Juki DDL-8700
I need find manual for my juki ddl 8500
Go to the website freemanuals.com They may have yours
Mar 30, 2010 | Juki DDL-8300
Juki DDL-8500
The DDL 8500. is a high quality, single needle, straight stitch, industrial machine. If it is still in a good condition and the present owner is prepared to guarantee it for at least 3 months, it is a good buy. Retail for app. $790.00 new.
Good luck
Jan 17, 2009 | Juki DDL-8300
Sewing Machines Logo
412 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
