Question about Electric Razor Pocket Rocket Scooter Mini Bike Bnib
Switch red light is on but will not run. - Electric Razor Pocket Rocket Scooter Mini Bike Bnib
The R & L brake lights don't work, but the center brake light (above the lift gate) does. Have replaced bulbs and also cleaned contacts - no improvement. What next?
Need year/make /model for more help. The brake lights run through the signal light switch if the signal lights flash red instead of yellow. If they flash red, suspect a faulty signal switch
Jul 18, 2015 | Cars & Trucks
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
Where are the fuses for blinkers
Cavity Fuse Color Description F1 -- -- Spare F2 -- -- Spare F3 10 Amp Red Headlight high beam left F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094) (Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier F6 15 Amp Lt. Blue Park lamps F7 10 Amp Red Interior lights F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks F9 20 Amp Yellow Power outlets F10 20 Amp Yellow Adjustable pedals (2002-2004 only) F11 10 Amp Red Rear window defrost indicator F12 10 Amp Red Auto shutdown relay / "Fuel" F13 -- -- Spare F14 10 Amp Red Headlight low, left F15 10 Amp Red Headlight low, right F16 10 Amp Red Headlight high, right F17 10 Amp Red Instrument cluster, diagnostic connector F18 30 Amp ? Trailer tow F19 10 Amp Red Anti-lock brakes F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center) F22 10 Amp Red Ignition Run / Start F23 15 Amp Lt. Blue Brake switch F24 15 Amp Lt. Blue Foglamps F25 20 Amp Yellow Accessory delay relay (sunroof) F26 15 Amp Lt. Blue Cigar F27 15 Amp Lt. Blue Rear fog (export) F28 10 Amp Red Body Control Module, Acc/Run F29 10 Amp Red Rear wiper switch. Washer motors F30 15 Amp Lt. Blue Radio F31 10 Amp Red Ignition Start F32 10 Amp Red Ignition Run / Start - Airbag F33 10 Amp Red Ignition Run / Only - Airbag C1 20 Amp Yellow Wiper (Circuit Breaker) C2 20 Amp Yellow Seats (Circuit Breaker) C3 -- -- Spare
I hope this helps :)
May 16, 2011 | 2004 Jeep Grand Cherokee
Have 01 harley wideglide. have placed 4 led lights with 6 lights per light each light has 1- 2 connectorwire red&black, tied al reds together, same for blacks. i can put reds straight to 12vdc,and...
You have to wire your switch in series with the lights. First, to make it simplier, use a two-pronged single pole single throw switch. Run a red wire from the battery to one of the prongs on the swith. Run another red wire from the other prong on the switch to the red wires of the LED's, Gound the black wires from the LED's. Now, when you turn the switch on, current will flow from the battery through the switch to the LED's and on to ground. I'd also put a fuse inline between the switch and the battery.
Good Luck
Steve
Nov 16, 2010 | Harley Davidson FXDWG Dyna Wide Glide...
I need a copy of the fuse box underneath the dashboard of a 2004 jeep grand cherokee lorado limited edition
Here You are...
Grand Cherokee fuses
1999-2004
Junction Block
F1 -- -- Spare
F2 -- -- Spare
F13 -- -- Spare
C3 -- -- Spare
Mar 07, 2010 | Car Audio & Video
Voltage on dimmer switch constant
That red wire is hot, it's used in what is called a 'switch loop'. That's where the electrician will bring the hot for the circuit to the light first, then run down to the switch and back with the switched hot for the light. Turn the breaker off!
Jul 09, 2009 | Leviton Decora Light Dimmer Switch
Downstairs toilet light switch needs rewiring
Yes, run a black wire from connector (a) to one terminal of your new light fitting if you are installing a metal fitting you will need to connect an earth wire also.
If you are reusing the same pull switch and it is still connected as you describe then the floating end near the light is probably the switched live conductor, so you could connect this to the live terminal of the new light. but be careful it may be live.
Caution always disconnect the power before working on electrical wiring.
Please remember to rate this solution.
Dec 07, 2008 | Electrical Supplies
Gas car wont run on gas only petrol red light on guage
red your dead...they are catching on...hence all the rolls..
and no update...all keys in my recent post today...
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Brake controler wire
It is red on the switch that is against the brake peddle arm
Jul 19, 2008 | 1996 Chevrolet Blazer
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Oct 20, 2007 | Hampton Bay 24002 Ceiling Fan
Electric Razor Pocket Rocket Scooter  Mini Bike Bnib Logo
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
