Question about Kenwood DNX7140 Car GPS Receiver
I have kenwood DX5260BT whitch has come up with DC Offset Error on screen
My screen on my kenwood dnx 6990hd says (DC OFFSET ERROR) What does thay mean
Basically that means there is an overload or some form of power issue with the machine.
The best thing to do is reset the unit to start with. Do you have the manual?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 28, 2016 | Kenwood Knob Dnx-6980 Dnx-6180 Dnx-6190hd...
Sounds ok but not dialogue...
It sounds to me like you are using the receiver in surround sound mode and the click you hear is the center channel turning off. If you have another center channel speaker, try swapping that for the one you are currently using. If that doesn't fix the issue, then try replacing the speaker wire. If that still doesn't fix it, then the issue is probably inside the receiver and may be either an output transistor that is failing when hot or an electrolytic capacitor that allows too much DC offset when hot.
Oct 10, 2016 | Kenwood KRF-V5060D Receiver
The auto return on kenwood kd5066 keeps shutting off before starts playing. how to fix
You has DC Offset(a damaged amplifier) This is most definitely not a DIY type of repair. If you're interested in a repair, or have further questions, please visit my website at audioserviceclinic.com. Thank you.
Nov 15, 2014 | Audio Players & Recorders
Kenwood with dc offset
DC offset is most often caused by the bias level for the output transistors changing for some reason. This could just be that the control is dirty and needs to be cleaned and re-adjusted, or the biasing network has a problem, most likely the diode or transistor that is being used to set the reference. The diode or transistor is often mounted to the heatsink for thermal feedback, which allows the bias to change depending on how hot the output transistors are getting, There is no mention as to how high the DC offset is. The usual range for DC offset adjustment is less than +/- 1 volt. If your offset is higher than this, there usually is a problem with the bias circuit that needs to be repaired. If it is MUCH higher, then one of you output transistors or driver transistors is most likely defective.
Jun 16, 2014 | Audio Players & Recorders
Miswiring dc offset
Saying miswiring dc offset error i unplug batt radio works for a sec till i turn up then comes back on
Jul 12, 2013 | Kenwood Ddx719 Dvd Cd Mp3 Ipod Iphone...
My kenwood ddx616 indash keep showin DC OFFSET ERROER?
You could have a speaker wire or speaker tensile (flex) lead that is shorting to ground, on a floating ground BTL head unit (all that claim 18-25 watts RMS per channel) all 8 speaker wires are always floating at about half of the supply voltage, IE if the voltage is 14.4 with the engine running the speaker wires will all measure about 7 volts to ground.
The flex leads are the wires on a speaker that go from the terminals to the cone.
Jan 30, 2012 | Car Audio & Video
What shall do if my kenwood show me protect?
Hello. It could be helpful if you would give us the exact model number of the Kenwood product you have. Kenwood has made many products over the years. While it's unlikely, your Kenwood product could be the subject of a recall or repair for this problem.
If it is not, please start out by checking your speaker wiring. If you have a short or bad connection, this can cause the amplifier in your Kenwood product to shut down as a way of protecting itself.
Check your speakers as well. Make sure all of them work. Also check the impedance printed on the back of each speaker. Compare it to the ratings printed in the Kenwood manual.
If none of this helps, and you do not find a problem, your Kenwood product may require repair. "Protect" is how the microcontroller inside the receiver is trying to tell you that something is wrong and if the unit did not shut down, further damage could result.
Apr 17, 2010 | Kenwood VR-509 Receiver
What are errors 1to5 and 7to8
1- face down sd ram failure
2 face up dram failure
3 cpu dram failure
Sep 23, 2009 | Kodak i30 Path-Through Scanner
Setting Digital Clock on radio/cd player.
Download the MANUAL here.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=037b5697f7192f25431654464fa26ba6&q=Kenwood+KDC-2011S
Enjoy!
;) Mak
Jul 04, 2008 | Kenwood KDC-2011S CD Player
Kenwood VR-405
Hi changeman5 Have you tried to do a full reset on the unit. Disconnect from the wall for 24 hrs. Then try again. If the problem persists, it may have power supply issues, or a DC offset problem shutting it down. If you are game, I could talk you through some more diagnostics...
regards
Graeme
Apr 01, 2008 | Kenwood VR-405 Receiver
Kenwood DNX7140 Car GPS Receiver Logo
576 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
