Question about Zanussi Washing Machines
Zwf 1621w stops mid cycle and then the on off button flashes
  • 4,323 Answers
Hi
First reset the unit by pressing the first and second button together and then turn the program selector button to OFF position. If this won't resolve the issue then check if the water is draining fine and try to clean the hose & pump. If everything is fine then check the Timer/control and the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 29, 2010
Zanussi machine washer. ZWF 1000M The wash button is red. The rinse button, spin button, and power botton is flashing red. This happened several minutes after tuning oN the 30 min cycle.
According to your description it is a failure E9- motor is not working. The temperature rises too high. The motor cut off for heat safeguard (Harness failure, PCB failure).
Dado
Apr 06, 2016 | Zanussi Washing Machines
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
Zanussi zwf 1437 starts cycle then stops midway. door light flashes. have to turn off machine at main switch to reset
This is a door lock fault, the lock is working initially but as the machine operates it fails, the only way to fix it is to replace the door lock assembly
Mar 07, 2012 | Zanussi Washing Machines
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Zanussi ZWF 1621W - fails to spin
Unfortunately this fault sounds like it could be the timer, the PCB board or even the motor. A pressure switch fault or blockage in the pressure bottle would cause the symptoms that it washes and distributes perfectly OK, but just wont do the fast spin. It doesn't sound like the case here. The jerkyness of the motor implicates one of the above causes. It's possible for badly worn carbon brushes to cause a jerky motor. If you had water on the electronics too, there's no guarantee it hasn't caused some problem. It doesn't look promising I'm afraid.
The "two air pressure sensors mounted at the top of the frame connected by pipes to the nether regions" must be the pressure switches.
Sep 26, 2009 | Washing Machines
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Machine stops mid cycle
Replace your control button(Start button).
Jul 22, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
